Wheel width question
  • Thread starter Thread starter bigred1969
  • Start date Start date
B
bigred1969
Guest
I am shopping for wheels right now here is the question. I have the tires already, 285/75/16 Cooper STT's, they measure about 33x11.5. I have WT axles. What width wheel are most of you running on the WT with a 12.5 in tire? I don't want them sticking out too far, maybe just past the stock flares.
I am torn between 8's or 10's, most of the ones I am looking at only offer one B.S. with say a 16x10. So I don't have much choice in that. I have narrowed it down to Mickey Thompson Classic II or a Xtreme Alloy 1059 both have about 4.5" BS for a 16x10.
Also, is a 10" wheel going to look too wide on a tire that is 11.5"? I fear that lowrider look from the 90's where the wheel was wider than the tire.
On an 11.5" tire I'd stick with an 8" wheel. The "rule" is the wheel should be about the same width as the tread which on your tire should be about 8.5"
If that is the tire you plan on using and you are 5x5.5" bolt circle then I would go with the 16x8 Mickey Thompson Classic II's.
They are pretty good fit up and look good.
My tow vehicle uses 265's on 7" wide and they look about right. I think that the 10"s are just going to be too wide unless you are truly looking at a 12.5" or 13.5" width tire.
Carl
Thanks, for the help. It will be 16x8, and M/T wheels. I had some Classic Locks before on a wrangler and liked them alot.
Now to find the deal on M/T ClassicII or maybe Classic Locks. Some on Ebay for around 515 for 4, not too bad.
