I have a zero miles rebuilt tf 999 out of an 84 that I have just about $700 into. Still need the flex plate, torque converter and a shifter. If you want it I would be happy to send it to a good home as I will not be using it now. If you buy one from a yard be sure to factor in the cost of at least freshening it up if not a full rebuild so you don't have the installation cost twice. as far as installing it, it shouldn't be much harder than doing a clutch job except you may have to also relocate the crossmember, not sure, and will have to do the kickdown inkage but that should be available as a stock item.
tr
