Which Winch?
OGRES
Ramblin' Wreck
BENEFACTOR
Suwanee
GA
I am in the market for a winch for the Scrambler but I have a bunch of questions about them. What size do I really need for a CJ-8 with 33-35" tires and a soft top? 9,0000-9,500 lb winches are a whole lot more expensive than the 8,000-8,500 lb versions.
Also, what brands are considered "quality" i.e., which ones are worth the extra money versus the ones that are just plain crap? I have seen various Warn winches up to $1,800 (for 9,500 lbs) and Rugged Ridge winches down to $400 (for 8,000 lbs).
Now I am the type of person who usually doesn't go for the high dollar stuff because of the costs nor do I go for the cheap stuff because I like to buy quality parts and equpment. I want to pay a fair price for something that will give me plenty of hassle free years of use. What brands are out there (Ramsey, Mile Marker, Smittybuilt, etc.) that have better quality at a good price? What types of winch do you use?
Any help is much apprciated!
I like to reputation and reliability of Warn and have been looking at the 8,000 lb winches. I just want make sure that 8,000 lb is the right size.
Warn recommends 1-1/2 times vehicle weight for winch size. This means anything over a 6,000# winch should suffice.
For most folks, an 8,000# winch is idea for mounting on a CJ. I went with a 9,000# because I wheel with full size rigs, some of which weigh over 5,000#.
Warn is the best and most reliable.
Make sure you also check out Clemson4wheel as they also have some great prices at times. Just checked, the M8000 w/roller fairlead is $539 w/free shipping.
I have the Warn M8000 and wheel the Rubicon a couple times a year among other trails. In the Rubicon I am usually carrying a trailer and have used the winch to haul my rig and fully loaded trailer through some rough stuff. That winch performed great. Typically they don't get used much so you might check out used ones on some of the boards. I've seen that particular winch go for as little as $250 used.
Thanks fellas. I have been looking through some websites and doing some more research. I definitely prefer to go with Warn but there are some good prices on Superwinch and Ramsey 8,000-9,000 lb winches right now too.
On another note, anyone prefer synthetic rope to steel cable?
Synthetic - nothing like being able to pull 50' of rope off the drum and then tossing the hook to someone up the bank. Just be forewarned - the rope doesn't like to touch anything when it's under load. You also need to protect it from heat and UV lights.
I have had my M8000 for two years now and have made 1 pull with it. I think it will last awhile, but when the cable gets old and crusty I will definitely go synthetic. They make delrin rollers to replace the steel rollers so you can keep that, or just replace it with an aluminum plain fairlead.
Off topic a bit, but does anyone remember that scene in "The Gods Must Be Crazy" where the Landrover climbed the tree on the end of its winch? Wonder what make/model that was.:eek:
I have an 8274 by Warn on mine and it's a good winch but I think any of the Warn or Ramsey are top quality, some of the others have reliability or other issues that I wouldn't be able to deal with for my rig.
For a trail rig I would use steel cable, I think the synthetic has it's place but not really on the where it might be prone to branches, lots of sun, weather, dirt, etc which the steel cable just soet of shrugs off but which serve to degrade the synthetic. Of course I say that never having used the synthetic on my own rig but having wheeled with some who do.
Also, remember that if you don't want or can't afford an 8000# you can go to 6000 or even smaller and use a snatch block to get the capacity up there to where you think it needs to be, I sort of wish I had done that to keep weight down
Good luck, let us know what you end up with
I run the M8274 with Pull-Master line. Id go (a good) synthetic over cable all day, but the wheeling here is a lot of up and down muddy, deep rutt tracks - so its a lot better than trying to run steel cable up a hill.
Just like you drop your oil etc after a wheel, I pull my line out, give it a bath in warm water and its good to go.
Thanks for the advice everyone.
I think I will probalby go with the Warn M8000 if the prices stay down on it. I have been looking for a new front bumper and mount too, so when the pocketbook allows, I am going to get them all together.
I have used Warn, Superwinch and Ramsey on our Jeeps. (and Tulsa on our Dodge Power wagon , but that does not count) Any of these are excellent winches made by Superior companies that STAND BEHIND THEIR PRODUCTS, even if you are NOT the original purchaser.
Some notes on winch choice, In my opinion, most wire ropes are WAAAAAAaay under rated for the sort of loads "we" put on them. You MUST be aware of the loads that not only YOU put on the winch on your vehicle but the average weight and load you could put on it unsticking your average wheeling buddy. It is not just the weight of the vehicle that most be contended with but the average load of the "*stuck" as well I talked in depth about winch loads with WARN and Super Winch (who both came to the PA Jeep show for the first time this year) The Only "standards" on cable are in the federal Hoisting standards which have a 7:1 safety margin, Winching according to WARN and Super winch have a 3:1 safety margin on failure. Consider that the safe working lad of a NEW high quality aircraft rated 5/16th wire rope is 1100lbs FAILURE according to the HOISTING standards and you should begin to see why winching is some of the MOST dangerous things "we" do in the woods. How does all this techno babble relate to your question? Don't skimp out on which winch you buy. Get a good one and get one that is "bigger" than you thing you need.
I am also starting to be a big fan of synthetic winch ropes as they ARE generally a little safer but more likely to be damaged. Again, you need to judge off your intended use. Read the owners manuals very closely, spend some time looking over the federal hoisting and winching standards (they ARE written in Blood) and see if you can find a Military manual on vehicle recovery, these are all great references. Synthetic cables are dead when they break so they "generally" do not carry the energy a wire rope does when they fail, this makes them a lot safer. But depending on your application you need to beware of some things, They need to be protected a little better than wire rope, they are sensitive to excessive sun light. (get a winch cover) They should be kept clean if possible, (wash them off after you are done wheeling) and protect them from abrasion. (don't run them over sharp corners, rocks or trees, use a aluminum hawse or a durlin plastic rolls on a fair lead. Beware that some synthetic ropes are sensitive to HEAT so if your winch uses a internal brake in the drum that will build up significant heat and could damage your winch rope. There are synthetic winch ropes that are NOT sensitive to heat but they are a little stiffer to handle, my synthetic rope is called "fire line" it is extremely sunlight and heat resistant.
Wire rope can be abused and take it for a good period of time, BUT when wire rope fails it fails with all the energy of the load almost explosively, any attachment on the cable like a chain, will Lasso (in the words of WARN) not much is going to stop a cable that failed until that energy is depleted that includes the Human body, cut in half does happen) Also wire rope damage is insidious and unless you are inspecting the cable it can sneak up on the operator all those little damages compound until failure and each one reduces the safe working load of the line so failure can happen at lower and lower loads. Wire rope also develop[es little burs as it wears that will quickly cut a un gloved hand.
Also don't think that the cost of the winch is it, it is probable that you will need battery and alternator upgrades to feed that winch. winch accessories and line bean bags or blankets to weigh down the line. Also you need to beware of your intended mounting points on not only the winch but all of your attachment points that you may pull against on your vehicle and anyone you intend to pull. One of the things I added to by bag of winching dirty tricks in a couple sections of 5" fire hose to protect my straps and winch lines from abrasion, ask a fire company for some next time they retire a hose.
* stuck includes LOADED vehicle weight, mud suction, mechanical drag, grade, mud depth, ground resistance, (pulling through rocks?)
