Who has Poison Spyder armor on their Scramble?
Sort of OT.
I am looking at the Gen-Right TJ weld-on tube flares for the back of my 8. I also found flares from A-Z Fabrication. Both companies have similar price, same part #???? Is this a coincidence or are the companies related?
Rob
I have the PS Fenders, Rocker Knockers and trail sides without the flare (I'm running a TJ flare).
Without the Trail Sides yet:
The sides getting installed:
The fit was great:
TJ Flares on:
I think the tubing is 1.25 OD tubing on the Rocker Knockers. Could be 1.5" OD, I measured it but forgot, lol.
It appears from the photo that you used the TJ flare w/out trimming the top edge of your wheel opening. I also see that the flare does not reach the bottom edge of the body. RATS.....
I wanted to trim the rocker and weld a rectangular tube to the bottom edge of the tub to create a offset similar to the stock aluminum rocker guard. I was hoping TJ flares would reach the bottom of the new rocker guard AND allow me to trim off the semi-rotten lip off my rear fender. I think I will be making custom tube flares too. Thank you Solidworks...
Rob
