Will Wrangler 1/2 doors fit CJ-8?
Scramblin_Jim
Goodyear
AZ
I ran across some hard 1/2 doors on eBay which are for 1989 to 1995 Wrangler. Will they work on my 83 CJ-8?
Yes, they'll fit fine. The only thing you'd have to figure out is a set of uppers that would work with the hard top (this will probably be a challenge).
Craig
No Uppers for now
:D Na I'm only interested in the lower half at this time. Just wanted something to put on when I have the top off. However over on eBay a guy had a very nice set of doors with sliding uppers off of a TJ. Not sure those will fit, will they?
TJ doors don't fit. You need to get YJ doors. I've heard some of the last years of the YJ doors use a different striker, so check that out. You want the post type, not the loop thing.
Haven't heard that one. I have a '94 tub on my CJ-7 and have a set of half doors from a '95 and they're the same old, same old.
Half doors fit just fine:
It is the TJ that has different strikers.
Originally they used the old style post type latch then about 2001 they switched to the u-bolt type latch. That means that the tobe doors that would fit my CJ and YJ would not work on the 01' TJ that I got.
Had to wait till recently to get a set that has a newer style of latch.
Carl
They'll work. Big tip*
Prior to trying to slam them shut for the 1st time slowly bring the door to the striker & see if it lines up.
If not, soak it down with PBBlaster overnight & loosin it up a tad to re-adjust the height.
IF it sticks into the door or not enough take the striker housing off & add or remove a washer as needed..
If you plan to keep the full doors and use them intermittently with the half doors, do not go moving the striker. You can adjust the half doors to the striker with the hinges. Be sure you only change the hinge location on the half door (versus cowl) or you will also be out of alignment on the next use of the full doors.
Hope this makes sense.
Later, Ken
