What are your opinions about Warn's "Multi-Mount" winch mounting system? It utilizes a Class III receiver for front and rear capability. In my case, the receivers would both be bumper incorporated and bolted directly to the frame.
I have one that I have been using on my Z for a few years now. Now that the Jeep is up and running I will be switching over to a solid mount rather than the multimount system. The theory behind it is great, but in practice it is somewhat lacking. There are 2 major drawbacks w/ it. You either have awful approach/departure angles w/ it hanging off one end of the truck or you have a storage/securing issue. The second issue is that rarely are you ever pulling in a straight line. The stress of a side pull on a receiver mounted winch is not a good thing.
The set up is good for very light wheeling,but as stated above you'll very rarely ever be winching in a straight line,I've seen these set ups bend the mounts to the point they have had to be cut off with a torch to get them off the vechicle.Then there is a storage promblem and then the theif promblem to deal with.-JC
