Windrock Trail Info?
kohldad
Goose Creek
SC
Does anybody have a link that describes the trails for Windrock? I have the maps, lodging info and such, but am having a hard time finding any information on the trails besides just a basic rating.
Thanks
Eric
What do you need to know?
What kind of info do you need?..........Some of the trails are very well marked and others aren't some of the trails have gotten more difficult.Unless your built and have extra parts or don't mind rolling then stay off of Rattlerock,Little Rattlerock,Trail 14 and i'd avoid trail 7 unless you have good brakes and don't mind a steep climb coming out with a small ledge near the top.Trail 21 is a fun trail but extremely steep going in from trail 15 and has severel off camber areas.Trail 2 is a long trail that is easy but scenic.If you have any doubt then stop and ask someone that is there and they should beable to help you.Just keep in mind the ratings are for 4 wheelers and what is tough for them maybe easy in a jeep and what is easy for them maybe a rollover in a Jeep.They have also been doing some work on some of the trails and main road in,so check at the permit booth for trails that might be closed.There is also active mining and timbering in the area so watch for restricted areas.In case you don't know everyone going into the ORV area "HAS" to have a $10.00 day permit on their body including passengers wheter they are in a carseat or 60 years old or a year use permit.They do spot checks from time to time using the sheriffs office and fourwheelers.-JC:D
Looking for info on the trail conditions and obstacles on the trails. The info you gave on the trails is exactly what I am looking for. Have already found out that the trail ratings don't mean much.
I have been there once and had a fun time. Had already heard about the fee change, big ouch for me since there are four in my vehicle. Still cheaper than a day at the water park though.
Saturday is a group ride where we will have everything from full locked rigs on 35s to almost stock so something like Trail
2->16->13->6 may be a decent choice. Where we can cut out the last two trails if time gets short.
Sunday we split into a hardcore group and an easy group. I will probably try Little Rattle Rock and Trail 7 on that day. Looked at Trail 7 last time and four of us agreed to try it next time we were there but figured we had a few places where winching would be required and didn't want to hold up the whole group.
Any info trails 53 and 54 in addition to a scenic way to get back to Oak Ridge if you come out the north end of 54?
So please, more trail info like what was provided by mulescj8.
TRAILS
I'll pull my Map tonight and give you some others that you might want to try-JC:D
easy ride/to Extreme
Take G1 all the across to far side of trail 11,pass the first trail 11 and if you run into the hiway you went to far and turn around and go back to to the first right,about a 1/2 mile or so up trail 11 you will come across a trail marker #23 if you have some HP and it's dry you can cut across this trail called a Atomic Ridge,and it will come out close to the end of trail 11,so the built groups and the stockers can meet back up-When you get grouped back up at the end of 11 go back to trail G1 which is the road you came in on,take the thrid right which should be trail 13,stay left where trail 34 splits off,follow trail 13 through the water crossings and mud to trail to G4,you will go left on G4 and this will take your group to a split........there will be 4 ways to go here.Stay on G4 to the Windmills,bear far left to trail 6 which is a moderate trail if it's not washed down the Mt. ,Continue up G4 to trail 7,which you know about,Trail 7 and 6 will meet back up at an intersection.for those that want an easy way out then they can run G4 past trail 6 and trail 7 to G2 and it's a gravel road back to where G6 and G7 come out at the top of the hill.Here is another run for another day take the first trail 15 or lower 15 to the top of the hill,hang a left on trail 21 and follow it all the way over to G5,hang a right on G5 to trail to G2 and then hang a hard left and take trail 3 at this point,little climb but sceinc trail with a good callenge coming out at the top of trail 3,there are two ways out,hard and difficult.........Once out you can hit hit G2 to P1 which should be the middle fork and a paved road which will go across the the exit of Rattle rock and then to the parking area-Hope this helps some-JC:p
