Winter projects?
AAAgghhhhh...... :eek:
Glad I've been saving so much $$ on things.
had to buy the Detroit Locker today. $550.
OUCH!!!!!!!!!!
O.k.
My winter project is taking all of Spring too...
That suck BUT I am nearing the end.
I got my axle housings and shafts shortend, bought all the gears, bearings and seals and dropped it all off at S&N to have the ring and pinions installed.
Once I get them back I will be ready to slap it all together since I have 98% I need to complete the project and 100% of the funding :D
Once I put the front axle together I will measure for my Drag link and tie rod. Tie rod will be 1" solid Chromoly with 3/4" Heims in the stock position, drag link will be full size tie rod ends, high steer.
I was able to buy a slighty used AGR steering pump so I hope the hydraulic assist can wait a bit (ha ha).
I got some used 38" TSLs (16" Rim) and am looking into beadlock pricing right now.
I found some for $85. each but am still looking for other kinds that might be a bit more expensive but be better for me since I still don't have a tow rig and am still driving to and from the trails.
I can't wait to get the axles done and am really feeling crappy since I haven't gone wheeling since I began this project, 3 months WAY TO LONG!!!!
Oh well I'm not alone (Crash) and I feel confident the hills will still be there when I'm finished AND hopefully with the new axles I should be able to wheel more and maintain less (less axle breakage/replacement)
I will get some pictures up soon as I get the axles under it, right now I've got a Jeep minus axles springs sitting on jackstands!!!!
Mark
Well I FINALLY GOT MY RING AND PINIONS SET UP!!!!
Yea!!
I took Friday off so I could go to Pull Apart to find some stuff for the Bucket (my daily Driver 1984 Toyota Corolla) I got the parts for $5. then decided to go up to S&N to help the guys out with some free labor.
Turns out they were inbetween projects and as we were talking Travis started pulling out my Differential parts :D
So I go to help set up my R&P and now know that I can do it my self with just a couple of simple, special tools and one Dial indicator.
Anyways we set up the Rear, then the front. Jason welded up the rear spider gears, ground down a tooth and a half (so I can remove the center pin to get the C-clip axles in and out)
Then I loaded it all up in my car and brought them home.
attachment.php
Since it's the holiday weekend I am not going to be able to do any axle work till Sunday.
Once I put these bad boys in I am practically home free!! (Knock on wood)
NICE... Sorry I couldn't get to them mark, my life is just an utter mess right now, but glad to see you got the goods and getting closer to hitting the trail....
No problemo Mike-man, I FEEL YOUR PAIN! :D
Hopefully we can have a Cherry breaking Reiter run soon!
O.k. FINALLY!!!
Here are some installed Axle Pics!
Here's the front.
I still need the tie rod and drag link but that's going to have to wait til next pay day! :D
Here is the big giant front axle knuckle and hub.
It looks small in the picture.
I am running all stock Dana 60 kingpin style knuckles. That means its Big AND heavy!
I got lucky with the front driveline, it bolted right up in the perfect position!
When I had the Dana 44 up there the driveline was a bit short, the dana 60 housing was just the right amount longer, At least I got to save a few $$ there, unfortunately the rear axle will need to be shortened one inch or so.
Here's a pic of the driveline angle.
Here is a picture of the rear axle installed.
It still needs to have the spring plates welded on, as well as the caliper brackets and anti wrap bar perches. That will come later.
In this picture you can see my SWEET custom gas tank positioning and heat shield. :p
O.K. after I got the rear driveline sorted out I ended up with a 1350 U-joint and 36 spline slipshaft out of a Chevy Fullsize PU. the slipshaft and yoke comes from the center section on the driveline right at the driveline carrier bearing. 1 ton trucks only!
Next I started it up and found out that the twin stick really didn't work very well and since a buddy of mine just got his setup fixed after a bunch of monkeying around with it I decided to buy a Currie-loook alike off E-bay for $60.
Got it and installed it. It is just as well built as the Currie one at half the cost.
I spent fathers day weekend finishing of the rest of the details, fitted the antiwrap bar, ground down all points for welding, bled the brakes (bled, and bled and bled) ran breather hoses and put the hood and doors back on her.
Tonight my friend Brad is coming over to tow me to his place where we wil weld all the afor mentioned stuff in place.
Then I wil be waiting for my Beadlocks. They should be at S&N Friday so if I get lucky they will weld them together so I can assemble them then GO WHEELING SUNDAY!!!!!!
If not I'l have to wait a full two weeks to go out wheeling since I wil be visiting my Mom on the 4th of July.
Let's hope all goes as planned....
The Saga continues......
I think I am actually going to beat ya :D
Bastard!!!
Well Brad welded up the stuff, now I need the beadlocks and to "dial in" a few things then I'm heading to Reiter on Sunday!! (I hope)
I drove around the block and to the gas station, starts in 3rd gear with the 30" garage tires I found in a ditch next to some train tracks, wraps up to 4000 RPMS quick!
Can't wait to get the meats on it, then Picture time and to the hils!
YEE HAW!!!!!!!!
My 6 month long "Winter Project" is nearing completion!
On a side note as we were returning home I started thinking, besides wheeling rigs why on earth would someone need 6:17:1 gears or the lowest 7:17:1 gears available for the Dana 60?
Hmmmnnnn...thing that make me go Hmmmnn...
:D
O.k. I got the beadlocks together and tires installed. They are not on the Jeep yet but will be tomorrow. I just finished adding 4° shims to my front axle to get my caster to the proper 6° angle for the Dana 60. I have a total of 14° worth of steel shims on top of that stock housing!!
Tomorrow I will pull the rig out of the garage, put the meats on it then go up to the high school parking lot to dial in the allignment.
After that I pack it up and head out for a night of camping with my lady then on Sunday a.m. the break in run at Reiter.
I am going to have a hard time falling asleep these next two nights.
I will post some final pictures after my next payday. The darn camera batteries ran out on me and I had to spend all my extra $$ on shims and misc. to get this thing wrapped up!
:D
O.k. after my first trip out for testing I burnt up a Power steering pump. Crash had Jeffs (zero to wow) old one laying around so I am using that with this modification now I have steering. I intend to do a hydraulic assist from West Texas but not till next winter ;)
This project took a long time and as usual for any Jeep project WAY MORE $$ THAN EXPECTED.
However after finally having a chance to wheel with my buddies this past Saturday I've found that it was all worth while.
Here is a final picture.
Here's another.
I ended up with a width from Side wall to side wall of 78" front and rear (+/- .5")
