Wiper delay
Going Postal
Corvallis
OR
Did the CJ jeeps ever come with a wiper delay switch that could be swaped in?
Yeah, I there's one on ebay right now. There's a different switch and a little delay module you plug into your existing wiring (where your current plug goes in). I bought another module from the stealership several years ago for about $100 thinking that's what was wrong with my wipers, and of course it wasn't. If you're lucky you can pick up the module on ebay or in a scrapyard and buy a new switch from qtech or 4wd hardware.
edited to add:
http://cgi.ebay.com/ebaymotors/ws/e...&item=7914857221&rd=1&sspagename=STRK:MEWA:IT
If yours is an 82 and it has 3 wire wiper motor you need the 83+ 4 wire wiper motor as well. I attempted this in my 82 and still haven't gotten it to work so if you do please let me know how. From what I remember, there only 2 wires in the 82 harness, white and yellow that go to the harness that connects to the module (which goes to the switch). My wiper only work in fast now, no meduim or intermitent which is strange.
Anyone have any ideas?
'82 here too... also looking for answers
Panther,
You beat me to it. I'd also like to know how to get intermittents on my -8.
Pls! If anyone has a solution, post it for those of us who are electrically-challenged.:confused:
I have had 2 different setups I bought off of Ebay a couple of years ago. I guess y'all raising this question will force me :mad: to have to see if either one works. ;) Of course my '8 is an 83 so we'll see. Shouldn't be to big of a deal.
I'll take pics if it looks really tough, but I don't think it is.
Can be my Saturday morning project.
Later
Ok, I drove the jeep to work today and will dig into it at lunch time. I'm assuming everything in mine works because I pulled the parts from an 83 cj. So parts include:
4-Wire Wiper motor
Module
Switch
Anyone care to check an 83+ for the wiring from the wiper motor to the module and the lines from the harness? Are there 2 wires or 3 from the harness?
That might help...
Also, TexasAg77, do you know what years your parts are for? 83 and up is pretty simple, it's the converting that I'm having the trouble with.....
Panther,
Not sure on year, but if I remember correctly, it is a 4 wire. I'll look when I get home.
I got my int. wiper setup off a Wagoneer. (mid 80's) I pulled the switch and module. After that it was just a plug and play on my 84. To do it on a CJ with the 3 wire motor you will need the 4 wire motor for a CJ and the switch, module, and the piece of harness from the round plug coming from the module to the motor plug from the Wagoneer There is a female plug in the wagoneer harness that will mate to the CJ 4 wire motor plug. I just cut it out to use on the piece of harness that I mentioned above. I've yet to get this wired up for my 82 Scrambler but I don't see why it won't work. I just need to pull the harness down on the my 84 and wire the piece of harness (above) like it's wired. Clear as mud????
Ok, i wired it with a yellow and red (w/ white stripe) wires from the wiring harness to the black plug. This plug/hanress then connects to the module which connects to the motor and switch (with a red plug).
Can anyone see what wires come from the wires harness of the 83+?
I hope is the same yellow and red wires and that I just have to replace something.
Yeah thx
I think that's what I did. I have the set up in my 80 chero as well and can compare the 2. It's just strange that they only work in fast.
Is the Wagoneer motor the same as the 4 wire CJ motor? I think I know where to get an 82 Wagoneer set up and was wondering if the motor would be a bolt in swap...
No, I don't think the wagoneer motor will work. If I remember right, I already checked that.
Panther, I've got some wiring diagrams at home for the 84. I'll look tonight and see if I can figure something out.
Hey Panther, I tried scanning them and it's hard to read the wire colors so if you have a fax available I'll fax it to you off the schematic.
