Wire Diagram
Wayne
Cape Coral
FL
Can anyone recommend a good wire harness diagram for the 82 Scramber inline 6.
I have printed a couple, both were different and some of the items on the diagrams do not cross reference with my Jeep.
In December I took the front end of and removed the dash - labeled everything.
Over the Iast couple of days I have put front end back, installed the the lights up front put the dash back -
The headlight work but I have no signals and getting no power to the cluster..
Thank you.
Wayne.
Belizeit
River Ridge
La
Try this one. PROSPERO's
Hoover
Bronzed Member
Livingston
AL
I've worked on a couple of these harnesses recently- one being an 82- and if you post up images of problem areas/wires, I might be able to help.
Also, if you haven't already, be sure to run a dedicated ground to your speedo cluster housing, as well as the other grounding points behind the dash.
Edit: Forgot to ask, is this an OEM harness or aftermarket?
Hoover
Bronzed Member
Livingston
AL
If OEM, this diagram may also be helpful-
  • CJ Wiring Diagram (2).pdf
Wayne
Cape Coral
FL
Thanks OEM.
Wayne
Cape Coral
FL
Apprecaite all the info.
It's complicated stuff - had another go at it today - no luck, just have head lights, nothing else - not even break lights ...
bigwalton
Alaskan Postal nutjob
FORUM MANAGER
Dexter
Did you find an FSM diagram to match your year and/or wiring harness? The key is having the right wire color/tracer labels matching up in order to make sense of them IMO. If you're having to fight to "translate" between what you have and what you're looking at on the diagram, it's a losing battle.
With things like you're doing with the lights, are you starting with checking the switches involved? No amount of wiring/light work will do anything if the switches aren't doing what they're supposed to and getting power from where they're supposed to. I always go back as far as I can and then work toward the thing that I'm trying to fix, checking along the way. So, start at the brake light switch to ensure you're getting what you need to make the brake lights work.
Dave The Sparky
Rebuilding my CJ8 very,very slowly...
Member
Halifax
UK
Have you plugged that long black plug back in to the steering column correctly as that would create most of the problems you seem to have. 🤔
83CJ-8
Trying to catch up
Silver Member
Lewes
DE
I sent the PDF from post #4 to Staples and had them print it out on a 24" x 36". It covered 18" x 36" and left the white border across the top. They thought they made a mistake so they printed it again. I had them cut the one down and I'm having it laminated. Total $14. When printed page 4 from post #5's PDF. :headbang:
Belizeit
River Ridge
La
I got it printed out on a plotter at work 2 copies Mine is 18 X 40 Garage walls are full. Need to figure out where it will hangimage.jpeg G
Wayne
Cape Coral
FL
Cool idea.
