WTF-Roll bar removal
Smokey65
Plantation
Fl
Do manufacturer's design things to piss off the average (or maybe below average mechanical) person? WTF would you put a bolt here?
What's the trick to getting the last 2 bolts out to remove the roll bar? Am I missing something or have others had a problem getting these bolts out?
you are not missing anything. Heat and pb blaster, atf, aerokroil, etc. I had to weld a nut to them to get some of those bolts out. nevet did get one out, gave up and sold the scrambler 15 years later.
Lol. I've tried PB blaster but not the heat yet. It's just damn near impossible to get a tool in the cramp space to get the damn things out.
Pop the torx bit out of the the socket and put a wrench on the hex.
If they are not too rusted in you might get it to break loose. Good luck!
If you've got a really good torch you can heat from underneath. Once that square nut gets hot you can get almost anything out as long as you can get grip at top. Results may vary.
this post reminded me that i have to buy another bit as i grenaded mine last week... impact gun set on destroy!!!
You can pop the torx bit out and cut some material off the length and slip it back into the socket. I have also used a swivel / extension or a 3/8" breaker bar as it fits better than the ratchet. X2 on the Oxy -Acet heat. I almost think that the factory used some type of lock tight also because my threads were very clean but still difficult to remove.
Removing the roll bar is part of the Scrambler owner's rite of passage.
Well, it looks like I'm not the only one that's had this battle, so that makes me feel a little better. I still think engineers/manufacturers do this as a joke, to be a pain in the arse!
They had to have a sense of humor...they worked for AMC...:headbang:
Smoky, I have taken a Dremel and cut slits in the head of the bolt so that I could take a chisel and drive it to loosen it
What are you complaining about... this was after 5 hours with a torch... LOL.
Seriously... they suck... badly... and I will finish the time machine and go back in time to find he who created said torx and have a chat.
Here is the easy way...
If you have another tub handy ;0)
If you run out of options, cut the heads off remove roll bar weld nuts on the studs sticking up. Mine came out after that dose of heat.
Just took mine off a few weeks ago. I got most off by using a cut off wheel on a grinder and cutting the sholders of the bolts so I could use a large crescent wrench on them (and this is after using PB blaster on them over a 2 month period prior to starting the teardown. Still ended up cutting the heads off 3 or 4 of the bolts. Will be welding a nut on them to get them out. I DON'T plan to put torx bolts back on there ;)
The poor torx bolt. It gets a bad rap cause jeeps rust so bad. It's not really the bolts fault !;)
The only other place i normally see and use torx bolts is in prisons to stop inmates removing things that are bolted down, maybe AMC thought we were not safe to remove parts from our own Jeeps??????
