- San Francisco
- CA
Pictured from left:
1981 CJ non-power brake T4 pedal assembly
1987 YJ manual pedal assembly
1995 YJ manual pedal assembly
I have not performed this swap, and inadvertently ended up with both 87 and 95 pedals. The 87 looks the same as the CJ but with lighter spring for the hydraulic clutch and and extra brace for the shaft. Besides drilling two holes, and swapping the brake light sensor brackets, is there anything else to think about? I know there was a small rod also used as a brace some or all years YJ - looks like where the upper left tab is on the YJ assemblies.
Maybe it’s better to make an additional brace out of sheet metal or plate steel.
I’m using the complete 87 power bracket/booster and master power brake cylinder from a CJ (to avoid changing brake line location). Any advice?
