Mounting Full Hard Doors
benserker
Help!
So I broke down and ordered a set of full hard doors from 4WD Hardware after looking for a while for a clean used set. I received the doors today and I tried to mount them so I could drive to a body shop to get a price quote on painting them. These buggers are hard to fit and I think that they might not ever fit correctly. I have loosened the hinge bolts and mooved the doors around numorous times and I still have a larger gap along the front seam than I would like, and the rear seam dous not fit flush with the tub, instead it sits about 1/8th of an inch proud. The worst part is that the striker pin seems to be to long and it hits the door if I do not lift the door upwards while I close it. I have already taken out all of the shims under the pin and there seems to be no other way to shorten the pin. Lastly, the windshield frame seems to be hitting the drivers side door as well and the only way I seem to be able to get the door to latch is by removing the bikini top and loostening the windsheild bolts on the dash so I can push the window out an 1/8th of an inch or so.
Is there a trick to this thing?
Please help...
Ben
'84 '8, MPI
fulll doors
Just keep playing....
you say you loosened the hinge bolts so I will assume you also loosened the bracket mounting bolts on the jeep side of the hinge....there is a lot of adjustment to be made there too. And when you do get them set wrench it all down and dont move the hinge (door side) bolts again. Instead loosen the top bracket bolts (jeep side) if you need to, to get the doors on and off. This is what I have found is the easiest way to reinstall and readjust my doors.
For instance it sounds like both sets of brackets (jeep side) need to move up and forward, with the upper bracket on the drivers side not moving forward but staying put or even back a little. this should give the door a little "tilt back" at the top. And yes your bikini top is part of the problem as you can plainly see it is pulling you windshield back causing interferance.
It takes me about an hour every fall to get each door aligned properly. Lots of cardboard wedged in to keep them in place while I tighten everything up. Like I said, just keep playing....
Anyone else have advice?
I would check the state of your windshield frame to cowl weatherstripping. My scrambler had the top front of the door making contact with the frame, and I think the gasket that the windshield frame sits on gets squished down and changes the angle of the frame. Hope that helps a little too.
Jon
Ben,
Keep us (me) posted on your progress. I'll be fighting this battle pretty soon. Also, I seam to remember Jefe had some comments about door alignment on a thread awhile back. Good Luck - Dwain
after four hours of screwing around with every possible adjustment I now have two hard doors that fit reasonably well. The main thing that was keeping the doors from fitting right was that the driver's side windshield hinge/upper door hinge was 1/2 an inch higer up than the passenger side. Also the hint about setting up the door side of the hinges and then not touching them and only adjusting the tub mounted sides really helped out on the drivers side door.
The order of adjustment should alternate between door side and tub side where you set one and then multiply-adjust the opposing side as much as possible. Remember also that the latch pin can be adjusted as well and some times it is easyer to move the latch pin an eight of an inch rather than try to figure out how to get that eigth of an inch at the latch side by adjusting the hinge side. (if that makes any sense)
adios for now
ben
resurrecting an old thread here... I would like to know if there's any play in the door latch mechanism inside the door.
I have my hard top on which sets where the windshield has to fall and my driver's door is hitting the windshield frame AND is too low to catch the striker.
No amount of adjusting seems like it will work because the windshield frame sits where the door needs to be... I moved the striker down as far as it will go and still have to lift it (so the door hits the windshield frame) every time I close it...
Seems like if I could just move the door latch down a touch, I'd be home...
Any thoughts?
Eric, have you losened up the hinges (on the door) and tried to adjust?
This should work unless I'm not picturing where your issue is. The hard part is getting the torx on the hinges to break free.
Truck
Any thoughts?
I recently installed new(er) YJ hard doors on mine, and I had trouble with the height of the striker on the driver's side. Easiest fix was to slightly elongate the holes holding the door latch in the door so the latch could be moved down about an eighth of an inch. Other than that moving the tub side of the hinges a bit lines both doors up.
I have tried the door side of the hinges... on the tub side of the hinges, the top one is the hinge for the windshied, right??? Does that move when you loosen up all the bolts? I wouldn't think that there's much play at all in that one?
Truck, my problem is that the angled steel frame around the vent window hits the windshield frame. So I can't move it directly up, it would have to get it to move up and back both and by a considerable amount.
When you come down for the Uwharrie run, I'll show you what's happening ;)
Don't forget that you can also adjust the rake of the w/s at those latches on the dash too, this allows you to ensure the windshield is square to the body. As stated above, once the door hinges are set, don't monkey with they, but i would paint before as they often rust under the hinges if you don't. Also, once the torx are loose, go ahead and replace them, I use some SS flat heads that use a hex driver, work well and don't rust up like the torx.
I've put off doing this myself because the driver's door latch os broken, anyone know how to get the outside latch mechanism off?
What do you mean? The angle that the windshield leans back or the side to side angle from left to right?
I can't play with the angle that the windshield sits at forward/back because the hard top sets that.
Eric,
You can set the distance from the top of the w/s to the back of the tub prior to installing the top. I'm not sure how your top is but mine will 'normal' half cab has some play fore and aft as well as side to side which affects how the doors fit and what they hit.
I'd have very little play in the windshield frame angle with my hard top. Maybe 1/8" at the top edge in order to still allow it to bolt down.
My problem is that the door hits the windshield frame really low, maybe 4" up the angled frame by the vent window. So it would take a ton of angle on the frame to change that.
I have a cheap aftermarket windshield frame, maybe that's what's causing the problem... I'll try to play with it some next week.
