OS - Cable vs DSL
fisherman
Whew, was that you?
brunswick
md
I currently have cable, but am being offer DSL much cheaper $29 compared with $59/month. I've read that it's not significantly slower than cable. Any opinions? Also, can you open up more than one web page at a time with DSL, and can you run more than one computer in the house off DSL (I currently have a broadband router to hook up a second computer to net service). Any of your computer whiz's have an opinion for me?
Fisherman's wife
Cable can be faster, however at $59 you are paying to much. It should be $49 at the worst for cable and you should find it $39.
DSL is just like cable in the respect that you can use a router. I didn't look at what ya'll had but you should be able to hook up at least 4 computers to that router and use the internet connection simultaniously.
Ensure you are not getting DSL lite which is significantly slower.
$29 is a good price. Also make sure DSL will actually work for you. You must be within a certain distance of the switching station for it to work. If you are on the edge you will get degraded quality. So, the closer you are to the switching station the better performace you will get. Hope this helps.
Truck
I agree with what Truck has said. Except I have noticed faster speeds on cable it seems. I have had cable in 2 different places and DSL in 2 different places...currently have DSL. I just like cable better...but the cable co. around here sucks...so it's too expensive. DSL is fast enough and it isn't dial up...so that's what I went with.
Yes, these days you can do anything with DSL you could do with cable. Throw it on a router, run 2 NICs in one PC...whatever. And it's also "always on" now like cable...didn't used to be...used to have to "log in"...that was ghey.
Cable Pros: Faster (in general..see con), I've found a little more reliable.
Cons: More expensive, everybody on the street is on the same hub..so the more folk that use cable modem the slower your connection speed..maybe your problem.
DSL Pros: Cheaper, fairly realiable, direct feed from phone company (you are the only one on the line)
Cons: A littler slower, the further away from the phone switch you are the poorer the performance, must put an inline filter (provided by the DSL company) on all your telephones
Truck
Truck said:
Cons: A littler slower, the further away from the phone switch you are the poorer the performance...
This can be a plus. The closer the better. It just turned out that I'm less than 1/4 mile from the switching station thing and mine is as fast as it could possibly be (I don't notice a difference from our near T-1 setup at work).
I can't imagine ever needing anything faster for what I do...
Just call the DSL company and find out how far you are from the nearest station. Also be very sure you're not talking DSL lite as Truck mentioned.
As others have already alluded to, there are different flavors of DSL, so be sure of what you're getting. Also, most of them still use PPoE for home users, they just 'hide' the logging in process in their software...you can use it with a router same as cable, however you'll need to setup the router for PPoE and enter your login info into it. DSL is very sensitive to distance and the quality of your phone lines. I'm on Comcast cable and they just upped the download speeds again this week...the performance I'm getting smokes what I get at work by the time our OC-3 gets down to my cubicle and surpasses T1 speeds. I just downloaded an ISO image of Outlook 2003 for SBS (building a new server at home with SBS 2003 to emulate one of my customers) off Microsoft's MSDN site last night that was est. 15 minutes on T-1 in about 10 minutes. If you're just surfing like the typcial user, DSL will be just fine for you. I work in IT and do admin jobs for a few small companies on the side and have 4 servers, 4 workstations, and 2 networked ReplayTV DVR's running at home, so I need the extra horsepower and the convenience of a truly always on connection and an IP address that doesn't change every time I connect...I haven't had to update my dynamic DNS service in over a year. I have a few customers whose home offices are on DSL and remote supporting them is a major PITA, cable users just need to leave their PC turned on and I'm good to go. I do have one customer with business-class DSL in their office, and that one is always on and has fixed IP addressing, so I have no issues with them.
Just make sure you're not signing a contract for 6 months or a year at $29 that twists way up after that period. That seems to be the game these days. I got bound up in a bundle plan and it hamstrung me, so never again. I gotta be FREE!!! whatever.
Or go ahead and try DSL for the period and if you don't like it, switch. Had SBC DSL and it was OK, switched to WOW Cable and it was a lot better(so far). Avoid satellite altogether from what I've heard.
Also a little off your question, I got Vonage VOIP and my phone bill is really cheap now, $16. 500 min LD, or $25 unlimited LD. Use me as a reference and we'll both get a month free (shameless plug). You run it off your broadband.
my .02
Paul
It's really good to read the comparisons here between Cable and DSL. I have Cable but I've always wondered which is best. BTW, last night I hooked up my laptop to my mobile phone for the first time. My thought was to be able to check email while at Tierra Del Sol this weekend (should I find the time). And I would have to find a lot of that (time that is)! WHEW was it SLLLLLOOOOOWWWW! :eek: I proved it DOES work...Unfortunately just not very quickly.
Thanks again for all the great DSL/Cable insight.
from the wife again.
I've searched the area for cheaper cable, but it seems we're dominated by one server, thus the reason to change to DSL if it's equivalent.
After all the responses from all of you "all knowing" folk, I am thoroughly confused and figure I'll just give the "free trial" a try and see what happens.
If you don't hear from Fisherman, my man, for a while, it will be because I thoroughly messed things up with the DSL and can't get the computer to work.
Thanks for all your insight, guys.
Wifie
PS. How do you guys get that neat quote looking thing to occur in your posts? and multiple quotes from multiple people? You're just too computer savvy for me.
Give it a go..ask these questions of your provider:
How far am I from the switch?
What are my download and upload speeds? (Make sure you are not using DSL lite)
Ask what guarantees they have on download/upload speeds.
You either hit the quote button on the post you want to quote and delete out the info you don't want included. Or use the "quote" bubble at the top of the message box far right side when replying to a thread. Then cut and paste what you want in there.
Truck
good advice (from all) & good questions to ask from Truck-
I have cable & like Jeepskate, they just upped the speed around here too!
WOOHOO, I'm faster at home then I am at work on a T1
here's a tip for anyone with digital cable tv- call the cable company & complain about the signal, I was getting a bad signal until they came & installed an inline signal booster. I asked if it will interfere with my internet cable at all & he said "no, as a matter of fact that will be boosted too" & he sure was right!!!! :D
