Rewind - Jeepskate II/XL project - 4/4/05 update
Finally got the Scrambler back into the garage a couple of days after Christmas after over a year of inactivity (it got bumped down the priority list due to 'life happening'...well, okay, mostly sh*t happening) and it's basically just been sitting since then due to other distractions and back problems. I've been on the fence the last few months about how to continue the build-up and after finding a somewhat local shop to do the work, I've decided to strip all of the way back down to ground zero and get anything that can be hot-dip galvanized, galvanized. I can't believe how much has rusted just sitting in the driveway under a tarp...basically anything that didn't have some kind of paint or coating on it has rusted...rotors, bolts, steering bracket spacers, tranny shifter brackets, u-bolts. I emptied all of the parts of out the back and removed the roll cages last Sunday, then yesterday I pulled the interior and the tub and today I removed the gas tank and everything else from the frame short of the engine & trans, suspension & axles, and steering box...plan to finish that up after work in the evenings this week and order up a few parts that I also want to have galvanized (tube fenders & rocker guards). Going to add some MORE frame plates to the front & custom plates to the rear (JeepInMatt made them for me a couple of years ago) then haul everything down to the galvanizer including the tube fenders, rocker guards, crusher corners, engine mounts, shifter brackets, steering bracket & brace, shackle hangers, u-bolt plates, front shock towers. Does anyone know if there's some sort of DIY galvanizing available for thinner brackets and the body? The galvanizer said that they can only do a minimum of 1/8" thick, anything thinner would warp. I'll post up progress with pics as I begin moving forward again.
-Rodney
-Rodney
