The little flatty--for a lil fella
So....what are all those plaques on the wall?
My guess is you won the "Fabricator of the Month" and "Welder of the Month" awards every month they gave them out, so they just told you to take them home so the other employees wouldn't get bummed out looking at your name so many times!:D :D :eek:
Nice work, as always!
Crash, that's some beautiful work! Keep 'em coming!
ha ha ha------thanks..
They are from work (chev tech). Al of those came form my 18 years at one dealership--and my schooling,lol..
Thanks randy--hopefully somebody can take some of my designs and use them on there own rigs....
This cage has certainly been a challenge--but thats one factor I truely love. And damn--this old thing is so twisted and----not square :D
Ok I am just putting along and kinda bouncing where my mind takes me...
So I went and bent the rear seat bar/B-pillar lower cross bar.
As you can see its bent to help let the seats slide back as far as possable/conform around them..
Now one thing I am really contiplating--and I bent the tube with this idea in mind. My idea is to notch the fender well on the inner/front edge to let the seats move back roughly 2.5 to 3" back. I know it doesn't sound like much--but with this rig thats alot really. The only problem will be boxing the cut area back up due to the staus of the sheet metal---so it might not be pretty if I end up doing it--but it will be pretty decent (some pretty thin areas in the sheet metal)
But I am pretty sure dale will say HELL YA make it happen,lol...
I also bent a rear support cross bar between the C-pillars. This bar will serve a number of things. First being some more support for the c-pillars. I don't really trust the tub to hold the fuel cell down---so the cross bar is going to aid in that and it also will give a landing for some more verticle tubes from the upper cross bar
So at this point I opted to work on the top of the cage. To help aid in more headroom--I chose to raise the upper B pillar cross bar roughly 1.60".
And I am just poking along now on the spreaders and have the last 2 almost ready to tack in...
So I am putting along.
So since I made some verticle tubes off the c-pillar that dove into the rear lower cross bar--I felt it was important to add one more cage support tube. So I lopped a hole in the floor and ran a verticle tube down thru the foor..
So I plated where the stock crossbrace and rear crossmember meet and made a mount for the tube to sit on..
So I didn't feel that the C-pillars had enough strength to them on a hard side hit. So I thought long and hard and this is what I came up with--and for some reason these 2 tubes were just lil bastards to get right on the $$...
I went and also added a spreader from B-C--plus will give a good strong location for tie down mounts down the road
I also got a few stringers on the A&B pillars done--getting closer
Nice work, Crash!
Do you use a bending program, like BendTech?
Randyzzz said:
Nice work, Crash!
I downloaded it once--tried it once--never again :D
I am one of those goofy fella's and just looks--bends something---looks and go goes from there. I have never even drawn anything...
Now that's talent! I am looking into BendTech- 'cause I'm the guy that looks, bends, and misses by a half inch...:(
Ok I got the door bars bent up. I went and tilted them/somewhat followed the contour of the tub--but will give a lil foot room for getting into the rig.
As mentioned before--I planned on notching the fender wells to get the seats back a lil farther. So I went and did some measuring, grabbed the sawzall and started hackin away. Nothing better than pure swazall agression..
So once I was able to get the seat into its full back position I went and figured the slope of the seat (3 degrees at the base) and also measured for the rear lower seat bar..
Once the seat mounts are all one I will re-sheetmetal the holes closed.
I went an flopped the windshield up to see how it looked...
Just enough room folr the mechanism to work and not rattle against the cage
So since I knew where the seats are and the slope--I went and bent up a rear cross bar from B to B pillar and the newly cut hole in the fenderwell gave just enouhg room to get the tube in and rotate it to its proper location...
With that done the front cross tube from the door bars was easy since I knew the slope. Then I cut up some bars that the seats will mount to. In the past with this style of seat I had the bars hug the base of the seat--but chose to run them out a lil more for future suspension seats if dale chooses to without alot of redoing tube work..
Ok after a lil bit of a well deserved break from the shop stuff its time to get back at this lil bugger....
Ok so prior to getting back to it I had cut/drilled the plates for the seats. I have never been a fan of using those universal seat adjusters. I have always looked at them as a weak link..
So what I did was make the seats movable--by unbolting them of course(I will be putting studs in the seats for ease of moving them/lining up the holes).
So the drivers seat has 5 positions from full forward to full back with the passenger having 3 (figured why not).
But in any case here is how they turned out.
So here is how the seat will look in the full forward position--perfect for the lil guy to drive it around---and try to see if dad can follow,lol..
So I grabbed the tilt column gibby had dropped off (out of a car) and cut the lower mount off and kinda threw it into a rough position.
After looking and measureing---this column just isn't going to work. Its too long and the width below the steering wheel is going to really be in the way.
At this point I am pondering just doing a straight rod style column--kinda like you see in a tubular rig. That way we can make the wheel removable for ease of getting into the rig, a better angle on the shaft and more leg room behind the wheel..
Crash- can you notch the bottom edge of the dash more to get the column up? I had to do that when I installed the GM column in my Jeepster. I also welded a plate on the tube for a firewall mount, and moved the exit point up. Looks like notching up about 4" would put the column just right. A new brace might have to be built- a horizontal bar with a couple of tabs works great.
I also have a spare GM tilt column, it's a shorty column. I was saving it for a rod project, but that will be years (and more) off. I can snap a pic and you can see if it will work. It's a lot shorter from the bracket to the firewall than a standard GM or Jeep column.
Here's a pic of the Jeepster column-
attachment.php
attachment.php
