The little flatty--for a lil fella
Here's a couple pics. It's about 9" from the bushing to the lowest mounting bolt (on the 4 bolt bracket). Above the bracket it looks normal GM length. The "cup" bushing on the end would need to have another bushing installed in it's place from a standard GM column. It came out of an Olds. Hope the pics answer any questions.
attachment.php
attachment.php
attachment.php
attachment.php
Thanks randy. I will compare it to the column I have and see if it is indeed shorter. As it sits now I am probably going to build a column--but I will make my final decision tommorow..
Well I hope everybody is doing well.
Randy, I am still holding off on the column stuff for right now, going to get other stuff done.
But here is an update........
I went and pulled this sucker out finally.
lots of choice words, a big thump
Followed by a rope and drug down the street
So it was time to finish the lower supports, With the trans and cross member out of the way, these had to be removed. First they are no longer needed and one support is landing there.
What was funny, once the 3 rivets were removed the bracket fell off there was a diamond shaped piece of metal behind the bracket. Now one would think that the rivets also held that on, not so. There were 6 spot welds holding that fawker on. So once that was removed, the area was cleaned and prepped.
Cut some more fish plates and got both sides done and ready for the short portions of tube next
I got the center 2 stringers done, and the underside fully welded up and painted at the frame.
I also got the body mount I removed reinstalled. I ended up just taking the one I removed and cut it down then plug welded it back into place.
God I hate doing sheet metal work,lol. Its not so bad but when going from old stuff where the thickness isn't constant to a constant material--I have always found it hard due to the lack of practice I get doing this type of work.
But in any case I got both sides of the tub at the front of the fender wells capped where I had to remove sheet metal to run the tubing.
So the next thing I wanted to take care of, was the fuel cell/tank. This was something that came with the rig and me and dale had decided it was ok to use (actually not a bad unit) and actually fit the rig pretty well (size wise).
So I sat and looked at the options of how to mount it in the rear of the tub. One thing I did come up with is the fact I did not want it mounted directly on the floor. This was due to two reasons. The first was due crap and stuff building up around and under the tank due to its location. The other was due to the floor, it was kinda wavy and not really strong (2 layers of sheet metal).
So the standoffs for the tank mounts it 2 spots. In the rear I made tabs, which are welded directly to the tub. In this area there is 3/16" material above the sheet metal that sits horizontal but bends and goes vertical to the frame--should work. On the front I hole sawed 2 holes through the floor to the cross member, so the standoffs can rest right on the cross member.
forum
forum
And here is the mount I built for the upper portion of the tank mount.
Here are the standoffs for the tank.
And here they are in place.
There are tabs on the standoffs to keep the tank in place.
And here is the tank down in place.
Now to retain the tank in place on the standoffs. I went and made some retaining straps, that sucks the tank down against the standoffs.
And here they are in place (tank is VERY solid).The strap assembly encapsulates the tank on both upper corners.
Some close ups of how the strap assembly mounts. Down at the floor area/front of the tank.
And at the back of the tank on the cage.
Lookin' good, Crash. Always impressed with your work.
I didn't hear from you on the column, so I ended up cannibalizing it for some parts I needed for a CJ column. I still have enough pieces to reassemble it, but they're not A1 shape (they have some stripped threads, chips, ect).
Thanks randy and no worries. I am looking at building a column for it. Since its going to be full hydro steering also and no turn signals and ect I can keep it simple. Plus it will aid in knee room.
update........................
Ok I finally got off my butt and got gibby a list of items I needed after figureing out how I wanted to do the steering setup. One thing I disliked about going with a gm/jeep style column--was the width--take up knee space--and I wanted to give this rig all the space I could.
I had to start by removing the stock column mount on the dash. Damn--did they use some damn big/strong steel rivates for it..
As I mentioned early on--I only tached the dash bar on because I was unsure of its location. I cut the spot welds, knocked it off and cleaned it up. I ended up dropping it down 1.75" fvrom where it was--I wanted to go more but I had to leave just enough room for the windshield latchs--its a tight fit..
I had seen this on a buddys rig and thought to myself--thats what I have been looking for. This is from polyperformace...
Found the sweet spot and tacked it into place..
And then tached the cross braces into place to give it some strength..
And here it is mocked up--I had my 13 year old son sit in it--and its going to be perfect.
I downloaded it once--tried it once--never again :D
I am one of those goofy fella's and just looks--bends something---looks and go goes from there. I have never even drawn anything...
Nice fab work as usual:bow:.......I'd be lost bending tube without bend tech....I'm extremely jealous that you can just see something and bend it to get it close.
Only criticism I have is those plastic seats.....those are a back injury waiting to happen. I rode around in a set once and I bought a set of suspension seats the next day.
Ya--they are not the greatest seat. I have had a set (3) in my own rig for about 5 years now--but mine are padded with high density and over that softer foam--works pretty well.
I have also updated my shop cam and now streaming live video
Linky
Saw that you posted an update on this crash but was on vacation and didn't have a chance to say how nice it was to see you back around here. :thumbsup:
Vacation--slacker :D
Thanks man--I try to get over here from time to time..
Ok time for some catchup. I got the cage fully welded finally--damn I am definately getting old and playing monkey isn't as easy as it used to be,lol..
Front fenders are welded with some cross supports.
My plan for holding the grill assembly worked like a champ. Just drilled/tapped and walla--grill is nicely held in place
When the fenders left I made sure to grab the shiney hold down clampy thingys(come on--I am a toy guy) for the hood. I simply drilled/tapped the tube.
The one and only thing that concerns me with the fenders is side support or there lack of. I still need to figure out a piece of tube that goes from fender to fender over the motor but tits going to be a tight fit. I can't get that done till the motor issue is 100% reolved.
Hood closed with the shiney hood hold down thing a ma bobs in place.
I went and gave the rig some grab handles. I really liked the placement of the front ones.
