The little flatty--for a lil fella
It took some time to figure out how I was going to do the fenders--since unlike a cj/yj/tj tubs you have a nice flat area to plate and land the tube. Plus I was origionally going to have the fenders wider but opted to make them narrow--so the lil rig can snake thru stuff easier and still give some protection to the hood...
Hey Mike are you going to add a cradle to the motor mounts?
I kept breaking the bolts off in the block until Darius added the tube going from one side to the other. No more broken bolts.
Of course I'm not sure if that guy whos havin the work done drives like me :D
Great looking work as always :cheers:
Thanks mark. In your aplication I could you having problems :D But in this lil rig I don't think its going to be an issue. This is the first time I have used that style of puck mount(don't like em). I prefer to do my own but he already had the mount kit so I used it. Granted the frame is pretty weak and even with all the tube work I will be doing to stiffen things up--its still how old and non boxed. But I warned him about that so as long as dad doesn't drive it--it should be ok :D
Right on mang.
Yeah those AA motor mounts are crappay. But hey like you said he already had em.
So whos rig is that anyways?
BIG_Mark said:
Right on mang.
Its gibby's 8 year old sons rig :D
Howdy everybody. Been a while since I have posted here--but I do pop in occasionally to see whats going. Plus I read an article in crawl mag about a bunch of ya crazy 8's playing in colorado :cool:
In any case its time to get back to this rig since the last one is done and back at its home :D
So--in any case back to the game..
So since I am still waiting for dale to get me a tranny I figured I would start throwing more tube at the thing. So since this poor body is just in poor shape and I wanna run the cage to the frame--I came up with a game plan to tie the cage to the frame and add some protection to the rocker area of the body...
One thing I found odd--when compared to the cj/yj/tj's is how they mount the tub. Its not only directly mounted to the frame--but the mounts down along the frame are opposite---the drivers side are on the inside of the frame and the passenger are on the outside of the frame...
So of course all landings of tube will be fishplated--but I ended up with this mount in the way on the passenger rear tube landing.
So I just took the plasma and burned off the rivate heads (one nice thing is they do use those steel rivates--and easy to burn off)
So I went and trimmed the new tube and tached it into place. This will not give a ton of protection from the side but will give all the protection in the world when landing on stuff--which is really where this rig needs it... Unfortunately I was not able to get a good fit/follow the contuer of the tub due to the waveness of it---but its pretty close... I swear back then they musta just eyeballed alot of stuff,lol...
The front lands on the lower tube of the fender---which will give it a good transition as you are sliding down stuff..
And here is where it lands on the frame on the rear side. Once its burned in I will cut the stock mount I removed and plug weld it back on. Not that its going to make it any stronger(tub) but might help keep some the rattle noises down(BIG maybe,lol)
forum
Ok so before I go any farther---dale had wanted to make sure the soft top is able to go back on--so I drug it out of the back shed--and gave it a good cleaning. Can you say drip dry,lol...
Man----doesn't it just look cute,lol... So took some pre-measurements and pulled it back off...
Now the fun is starting...........
So I went and looked/figured/looked some more as I often do,lol----then measured some tube and threw it in the chop saw...
So I started by lopping a hole in the floor for the A-pillar..
As you can see the A-pillar will land on the new tube--and I had to notch a pinch seam a tad since the tube hugs the tub nicely...
Some more figuring/bending
For some reason I lost my measurement where the soft top sat in the rear--but luckily I remembered where the rear support sat. So located that and knew where the tube could not be,lol. Took some measurements and tossed the tube in the bender and thats as far as I got today
Ok I have been poking along on the cage and this thing has been a tough one but fun---love a good challenge.
But here is how it sits now--and remember there is more tube to come..
Here is the A-pillar diving onto the new under body support...
The B-pillar was the tough one. It took some work to get the holes thru the tub just right and with where the underbody support sat--the b-pillar had to dive a couple degrees once it went thru the tub. But after alot of notching and figuring I was able to get what I wanted. I also wanted it to hit the main a-c bar right where I had an 8 degree bend--so it was tricky.
The bottom lip of the floor had to be notched along with the hole in the fenderwell..
One thing I pre-planned was how the C-pillar turned out. Due to how the A-C pillar was bent---I had to cut it and then make downbars/sleeve the tubing which turned out perfect. I also platted the frame where the C-pillar dove into the frame..
I have already planned cross supporting to help strengthen the C-pillar---as it stands alone it really isn't that strong....
I chose to bend the dash bar forward--to help with room----As it sits now I might move it once the steering column/seats are figured out. But there is just enough room to get to the windshield latches..
A pic from the front. Its funny how the angle of the camera came make something look unlevel,lol....
There is just enough room to rotate the soft top supports from the laying down position to the upright position....
