entended yj project looking for ideas
by the way this is my Jeep that i am considering doing it with...
so my question now is after searching ebay etc. does any place make restoration or repair pannels for the cj8
I saw a nice one cj8 in WPB near me but they want 10K fo rit. and i just would not have the hear to take something like that out to the swamp...
so if i could fina rear batch pannel i migh be able to use that to build my extension.. thoughts???
ya thats the piece and the floor and tail light are seprate. could be $1000 just in parts for that little bit. I would be better off extending the wheel base for that.
Guess Ill have to keep looking for a junker jeep.
any other thoughts ???
If you want extra wheelbase, I would stretch on a diagonal behind the door support. This isn’t mine but it shows what I mean.
JCWhitney sells CJ7 floor panels for like 80 bucks that you could use to fill the gap in the floor. There was a thread on here were somebody used two of these to make a CJ8 floor.
http://www.jcwhitney.com/REAR-FLOOR...0444_N_111+1985+200734027+600018862_10109.jcw
Probably could do this cheaper than a 1K. The extra wheelbase is nice, but I am a little bias, after all, this is a Scrambler forum.
could someone get me the measurement of the area behind the rear wheel. see the red line/arrow.
This may be moot now and these are NOT precise measurements, but:
A CJ7/YJ tub is about 93” from the firewall to the rear
A CJ8 is 117” for the same distance, ten inches in the wheelbase and 14” behind the wheels, so 24” more overall.
I've never owned a CJ6 or an LJ so the following is not first-hand info. The LJ is 15" longer than a CJ7/YJ (10" in the wheelbase and 5 behind). The CJ6 tub would be 10" longer than the CJ7/YJ tub.
I know you are looking at some kind of SUT but you might want to match another model just in case you wanted to go to a full-top somewhere down the road.
i thought of the too then extend the frame rails etc and not worry about the spring mounts just cut in half and then push it back.
I wonder what he used for those filelr pannels.
wish i could see the underside and the inside of the jeep.
did you find this picture on the net or know how to contact the owner?
maybe it would be worthwhile for you to reread Jeff's Retro Willys PU thread and see how he did it correctly and you could adjust your idea from there. It is a proven, factory quality (or better) job that could be applied to your project in general terms, especially the planning aspects of how to get from where you are to where you want to be
Ill have to find that thread. mind you this is not a show but a wood and daily driver that i want o build but i would love to know how he did it and do it right.
ill try searching the forum for the thread.
I'm delivering the wife's yj monday to a shop here in tulsa that will add 10" to the frame and body. Doing to the cut just in front of the rear spring hanger for the frame and down the center of the wheel opening for the body. Infilling the panel and the remaining arch with new sheet metal and inner fender panels.
I will get to post up pictures as it progresses next week....
so i ran into a guy with a CJ8 yesterday and it looks like th eoverhang in like 18" long. Ill have ot send him to this site. He is restoring the CJ8 now.
From where to where are you measuring from to get 18” long?
back of hte rear wheel well to the back of hte tub just before it curves around for th elights. there is a seam there.
ya that is what i want like another 10 behind the back of the seat. Please do post up pictures as you get the work done.
So what will you do for a top? I want to leave mine factory and have an open bed are to haul gas tools etc.
So you will be cutting the front rear hanger to be clear behind the driver seat? and relocating your axle back?
I had considered that but that may be to involved for me. not sure how much it would cost either
The frame will be cut just foreward of the rear spring hanger. we will cut off the body mount that is right near that.
I will dig up the photos of my jeep. I transfered everything over to a super clean '82 scrambler frame with the rear extensions cut off and cut the body to fit.
I will scan some of the pictures and post them up.
Maybe get another cj/yj tub, and cut the back off of it, extend the frame, and attach it to the rear of your jeep. That way your cab will still be enclosed and you can gain the length your looking for. You could patch up your tub in the rear, relocate the filler to the side. Turn the original tailgate into a sliding door of some sort for additional access.
But CJ7/YJ tubs have different wheel openings, so that measurement doesn't really transfer.
Some of the ideas being discussed here sound like they are technically feasible but aesthetically horrible. If you're going to go through all that work and expense, I think you'd want to end up with something that looks reasonably decent. Here's a few concepts (not all good :) )
The first one is a YJ wheelbase, tub stretched to Scrambler length, with a YJ hardtop. Loks goofy to me, WB too short and overhang too long, "bed" area too small, hardtop obviously not designed for the vehicle.
The second one is the same thing, but on a Scrambler wheelbase. Still looks goofy to me, bed" area too small, hardtop obviously not designed for the vehicle.
The third one also isn't my cup of tea as they say, but the I think the proportions are getting a little better. It's a Scrambler wheelbase, with a rear seat, and a YJ hardtop shortened to just behind the seat. This gives a "bed" that's long enough not to look too goofy, a decent wheelbase, and a cab sized for two rows of seats.
I think if you lengthend the wheelbase of the last one another 10" (to 113.5), and lengthened the bed another 10", you'd start getting in the range of aesthetically pleasing proportions, at least for my taste... maybe I'll draw that one later.
Anyway, just some food for thought and some personal design observations, which may not be valid or to your taste and certainly may not be worth anything at all.
attachment.php
First of all I love all the feed back good bad the ugly LOL.. That's what I want. Jeff you are the man. Thanx
I wont be putting a hard top on as I dont have AC any more and heck I live in FL and like going topless.
The middle one is more what i was thinking of. Ya may be it will look to goofy. I have a feeling liek your builds this will be a long time project and parts scrounging.
I may have located a YJ tub that was wrecked in the front. no frame just the tub. How much do you think i should offer on it? I think he said he wanted like $500 but I think that is high especially with out a frame.
I did located a CJ tail gate and hinges and cable for like $80 in good shape so i snaged that.
Thanx for all the great feed back and keep them idears.. (ya Im from Boston) coming. :rotfl:
