speybro
- Blackfoot
- ID
Here is my other Jeep Project for hunting dogs. It is not a Scrambler, but it has been elongated to Scrambler length. I have re-cut the Best top to end behind the roll bar. It also had a lot of extra roll bars which I took out, and i made two 5.5" bars for the sides to hold the aluminum 6 dog box. I can't get pictures to you of all the changes, as this unit is in Idaho and I am in Texas but this is what I started with. I also welded in some steps to get my fat *** into the cab. I will post pix when I get back to Idaho.
Extreme Low Gear Rock Crawler Jeep
429:1 Gear Ratio
This 1990 Jeep Wrangler has been built with extreme rock crawling in mind from the start. The engineering of this rig was centered on minimizing weak points while increasing overall strengths. This Jeep has easily handled the Hammers, Rubicon, Irshim Trail in as well as some of the toughest trails the West has to offer. This Jeep has awesome articulation as well as INSANE crawl ratio allowing you to attack any obstacle with confidence. I won't be doing the trails, but I do need this to go over lava rock while hunting Chukars.
• Stretched to 105”
• 4.0 Liter Fuel Injected Engine /w Rocket Air Tube
• NV4500 Transmission (Dodge Model 5.61 First Gear)
• Atlas II 4.2 Transfer Case
• Klune V 4.0 Extreme Under Drive (David model)
• 456 Gears
• Dana 44 HD High Pinion Front w/ Warn Hubs 456
• High Steer
• Rock Ram Steering
• Reverse Shackle
• ARB Lockers Front I will put the same in the rear and take out the welded spider gear.
• Dana 60 Rear (Welded) 456 From Ford 74 or 75 Van
• Diff Guards Front and Back
• Tera Flex Revolver Shackles
• Rancho 9000XL Shocks w/ in dash remote and compressor
• Onboard Air (York) w/ Air Tank will fill 37" tires in 3 minutes
• Warn Rock Crawler Front Bumper
• Warn Rock Sliders
• Custom Large Skid Plate 1/4 “
• Warn HS9500i Winch
• Rock Hard Full Roll Cage, I took some of this off to make room for dog boxes
• Custom Anodized Blue Aluminum Dash
• 37” Goodyear MTR Tires
• Rock Slider protection both sides
https://www.cj-8.com/forum/attachment.php?attachmentid=15348&stc=1&d=1260974411
https://www.cj-8.com/forum/attachment.php?attachmentid=15349&stc=1&d=1260974411
429:1 Gear Ratio
• Stretched to 105”
• 456 Gears
• High Steer
• Rock Ram Steering
• Reverse Shackle
• Warn Rock Sliders
