overdrive on the cheap for V-8?
JEEPTHRILLS
CHEAP overdrive (auto or manual) to live behind a basicly stock 360. with wither 4.10's and 33 or 35's, or 3.55's with 31's.
opinions?
Good luck with that, I'm afraid it either a new tranny with the OD in it or the Ranger by AA or the gear vendors, Cheap is relative and neither of those meet my definition but maybe they do meet yours. I'll be watching for replies too
what do you think about the ax-15 or the NSG370? Novak seems to think it will handle Chevy small block power?
How about the NV3550? I think it can all be cobbled together with stock parts...supposedly stronger than the AX-15.
Put a T-5 in it and drive it like a grandma:shrug: That will be cheap and pretty much bolt in, but not too strong:(
A guy in our Jeep club has a CJ-7 with a 360/T-5 combo and 36 inch swampers. He rides it very, very hard. Has to rebuild the tranny about every two years. I think he told me keeps busting main shafts in it.
now that is scary!!! even if i could come up with all the world class parts.....i dont know. the worst thing is I have all the parts for that...except the flywheel. :eek:
I usually like to just do it once...do it right...but in this economy... I just need a reliable road rig. Even with the 3.54's and 31" tires....i hit the bottom of hills as fast as possible and end up at 45 mid way up.
Like I said, I wouldnt recommend it, but a rebuilt T5 drove easily might last a little while. You should be able to get a flywheel cheap enough, the rest is pretty much bolt in. You can usually find T5's fairly cheap (guy in our local club has 3 of them he would sell for $300 just to get them out of his garage, talk about spare parts for cheap:eek:)
Could hold up:shrug: 31 inch tires and road only use might help it out:shrug: Since you have the parts already, might be worth a shot:rolleyes: Since you have most of the parts, sounds like you could do it cheap. And if it does blow up a couple months down the road, at least you didnt invest too much money;)
If you do go with a T5, keep us updated on how long it lasts:rotfl:
cheap overdrive !!!!!! run the 3.55's with the 33's or 35's:shrug:
2349 rpm w/33's--------2215 rpm w/35's may be higher w/the auto slipping alittle
fortunatley the 999 is a lock up so there is little to no slip.......it just has no power at the bottom of 3rd gear!!
Plus if i put in the v8...i will loose A/C till i find sanden compressor brackets from a Pacer or FSJ.
I think I need to try the 258 out with the t5.....see if I can find a set 30's with the 3.54's.
already have a fresh t-5.....just too scared to do it!!!!:eek::eek:
Sell the T5 and drop in an AX15. The AX15 is a good medium duty transmission with less issues than the 3550 and are dime a dozen because they were also in the Cherokees. I know guys that have put them in FSJ's. As long as you treat it like its a medium duty tranny you will be fine. I have one sitting in the garage that will end up in mine if I don't get pressured into an auto swap by the family.
i think i am destined to just toss on a 4.0 head, and deal with the t-5. Anyone in cali?? Would a 4.0 head (with out AIR ) and a junkyard EFI pass Cali somg? My 2 most recent job opportunities are in the Bay Area.
