Fuse
So with one wire of the meter on the red/orange wire of the speedo and the other end of the meter on the red oil wire, the reading is zero ohms. That means it is the same wire, as it should be, maybe they just ran out of red at the factory that day and used a little orange.
You can put that wire back on the oil gauge and put in a new fuse.
Leave the red/orange wire off the speedo post so you can drive around without blowing the fuse, you should have your 4wd light and oil pressure unless something else is broken with them.
With the speedo post wire off and the purple and pink "goes outa" wires off the speedo, take a ohm reading between the speedo post and the metal frame of the speedo gauge, anywhere on the back. It should be 1K, but it sounds like it is going to be zero, which is why you are blowing the fuses. Check it an see what it says.
I am not sure if there is anything in common here but the 4WD light does not work when I engage 4WD H or L even though the bulb is good
I wouldn't worry about the light not working right now, I think we can start a new thread to make that light work, let's stay on the fuse blowing. I'm heading out to dinner with my wife, be back tomorrow....I think 4miles can drive from here....
Rustcrawler,
I spoke with Wayne and he is going to mail me the speedo to check on mine and possibly repair.
Rick (4miles)
Well, I think we are ready to fix the problem. There are no magical wires running around inside the gauge. I think the problem is that one of the posts is bumping up against the chassis or the nut that holds the post against the chassis is touching the metal of the chassis.
I'd loosen all the nuts, take off the jumper, pull back the paper, make sure the posts are centered and not touching the sides, put the paper back, making sure there are not holes in it, maybe put some electricians tape to ensure that it is insulated, put the strap back on, put the nuts back on, and test again for a short.
If that don't work, it's bumping on the inside.
I think perhaps when it was being cleaned the nuts came loose and they just need to be straightened out or one of those nuts was tightened through the paper.
Cheers:)
4miles,
I hope that last post didn't come off sounding A whole ish. That was not my intent. I just think that it might be easier to try loosening five nuts, straightening them out, and testing one more time before he mails it off.
It's interesting if both gauges are having the same problem.
Wayne, you have two gauges and they are both doing the same thing?
4miles,
Wayne, you have two gauges and they are both doing the same thing?[/QUOTE
RustyCrawler,
I spoke with Wayne for a while on the telephone and he was very gracious for all the help. First I had called and gave him a few quick pointers on using the meter. Yes, both gauges are doing the same thing and that is one on the things I was going to check. What puzzled me is when he says he put the new one in and the temp went to full and blew the fuse and has blown immediatly ever since. It could have fused a good short at that point. That is a good point you raise above and if he sees before he ships, he should try first. He first lost his fuel gauge and his temp went to hot. Seems the fuel sending unit went first. He has since replaced the sending unit for the temperature. He is shipping the new one. I figure it would only take a few minutes to ground and hook the 3 wires to, test and at least know right off whether it is a good gauge or not. Quicker than typing.:D Why I say that is a very good point you raise above is the fact that he removed the strap on the original and put back and also on the phone he mentioned that when he first got the new one it was off in the window and he moved it. So I am sure if he sees this he will check or I will call and let him know.
I did not take that as Awhole-ish. I have been very impressed with your effort and willingness to help a fellow member A++.:)
RustCrawler:
Thanks for the advice. I did what you recommended regarding the post inside the cluster.
When I turned the ign on the fuse DID not blow. I was talking to 4miles at the time and it sounds like like the CVR.
I am going to test the cluster with the meter and check the OHMS.
Thank you very much.
wayne.
Wayne,
Excellent! Now that you are all checked out on reading ohms with your new meter, there is a great link here that will tell you what all the readings should be between the different posts. (you have to pull the red/orange, purple. pink wires off first)
http://www.jeeptech.com/electrical/gauges/
Now that the fuse is not blowing, are the gauges actually working? How about that 4WD light? If they are not, I vote we start a new thread call "Temp Gauge Not Working" or whatever. It's been fun, sorry you had to blow so many fuses along the way.:thumbsup:
