Wayne
- Cape Coral
- FL
So with one wire of the meter on the red/orange wire of the speedo and the other end of the meter on the red oil wire, the reading is zero ohms. That means it is the same wire, as it should be, maybe they just ran out of red at the factory that day and used a little orange.
You can put that wire back on the oil gauge and put in a new fuse.
Leave the red/orange wire off the speedo post so you can drive around without blowing the fuse, you should have your 4wd light and oil pressure unless something else is broken with them.
With the speedo post wire off and the purple and pink "goes outa" wires off the speedo, take a ohm reading between the speedo post and the metal frame of the speedo gauge, anywhere on the back. It should be 1K, but it sounds like it is going to be zero, which is why you are blowing the fuses. Check it an see what it says.
I am not sure if there is anything in common here but the 4WD light does not work when I engage 4WD H or L even though the bulb is good
Why I say that is a very good point you raise above is the fact that he removed the strap on the original and put back and also on the phone he mentioned that when he first got the new one it was off in the window and he moved it. So I am sure if he sees this he will check or I will call and let him know.
