World Cab/Alaskan Postal Hardtop Windows
jscherb
Elmira
NY
Our newest Alaskan Postal owner on this board sent me an email asking for advice on how to put side windows in the hardtop, so I thought rather than sending the info to him privately as long as I'm writing it up I'll post it here in case someone else needs it now or in the future.
This will be in two posts because of the 3-photo limit per post.
In the first photo below you see the inside of the side panel of an Alaskan Postal hardtop. Most of the insulating foam has been removed but there's still some to go. You can see a recessed section on the inside panel; we'll use that for the window. The only problem is that horizontal bar across the window space, if we just cut that out the rubber window molding won't fit properly where it has been cut out.
attachment.php
To solve this, cut the bar out on the lines as shown, and the cut a patch out of the removed bar as shown below.
attachment.php
Continued in next post.
Jeff
Continued from last post...
In the next photo you see the patch in place. You'll need to do 4 of these, two for each side. This needs to be welded, but don't weld it just yet, see the next step...
attachment.php
The sides of the World Cab hardtop are gently curved making it pretty much impossible to get flat glass to fit and seal properly, so we'll have to straighten the sides a bit so we can put in flat glass.
Before welding, clamp a straight board in place as shown to straighten the side panel curve a bit. Once clamped, you can weld the patch in, and also put a few tack welds along the joint between the inner and outer panels, because they aren't fastened from the factory. Do this for all four patches.
attachment.php
Now you can take the completed side panels down to your local auto glass place, any decent glass shop should be able to cut a piece of safety glass to fit and install it with a standard rubber window lock strip. My windows cost me about $100 each.
Here's the final result:
attachment.php
Jeff
Great!
Thanks for the post! You saved me some pretty large potential headaches...
Jeff,
This will be very helpfull . Have you ever reasearched the company that actually produced the World Cabs ? If you look in Venezuela they were options on the Streched wrangler(CJ-8) and Cj-7 until 1994. It is hard to believe that they were shipped that big of a supply from the USA to run that many production years with them.
Thank you,
Tim
I don't know if they were made by Jeep Venezuela or some other company. Parts like this are often subcontracted to a sheet metal stamping company, but I've never seen any references to how these were manufactured or who did them. Sure would be a good thing to know!
It seems that these hardtops are still being produced in Israel as part of the AIL Storm M-240: http://www.ail.co.il/storm_v.htm.
I sent them an email once but never got a reply.
A good friend of mine is from Lebanon, he says these hardtops are common there, probably produced by AIL. I told him next time he visits home he has to slip one in his carry-on bag...
On a related topic, are any of you planning to put a headliner in your World Cab? I finished my headliner last summer but haven't done writeup (yet).
Jeff
World cab owners UNITE! :cool:
Nice writeup Jeff. I don't know why you'd want those windows over the HONKIN BIG blind spot, but to each his own ;)
world cab
Has anyone been able to find replacement weather stripping for the side and rear doors? All so the rubber gasket that is around the rear door window???? Does anyone know if there would there be any avaliability of parts from export locations (australia venezuela...)??? THANKS DAN!!!
I haven't seen exact replacements available anywhere. Some ideas:
- Side doors - make new weatherstrips out of two sets of standard "round corner" door weatherstrip. Cut off the round corner part and replace it with sections of a second weatherstrip, join with black silicone and perhaps some foam strips inserted in the hollow core. I didn't have to replace mine but I'll tell you why at the bottom of this post...
- Rear door. Is it the same profile as CJ tailgate weatherstrip? I don't know because when I did have a tailgate on my Scrambler before the World Cab, the tailgate didn't have weatherstrip. If it is the same profile, make a new one out of two or three tailgate strips as above. Mine was in great shape so I didn't have to replace it.
- Rear door glass. That's a bit hard I think because the glass is larger than glass normally would be for the opening. I tried some ordinary window lock strip but the glass was too large, the glass plus the rubber strip wouldn't fit back in the hole. My weatherstrip for the rear window was actually in pretty good shape but the second World Cab I picked up had even better condition weatherstrip so I substituted that. I'd recommend a trip to an auto glass place to see what they might have.
I also have a huge auto weatherstrip catalog I picked up after my World Cab resto was completed so I've never looked in it for something equivalent to substitute. I can check it to see what they've got.
Why I didn't need World Cab weatherstrip for the side doors... I switched to standard CJ "round corner" doors. That way I can use easily available weatherstrip and glass. It is fairly simple to fabricate "corner fillers" that seal well. Here's a photo below. Plans for the corner fillers available on my Overlander project site: http://home.stny.rr.com/jscherb/scrambler/hardtop.htm (bottom of the page in this link)
Jeff
I know this in an old post but.... Do you have any info on who you got the side windows from? I'd really like to do a Postal with a slider window of some type but that will require a frame rather then just a rubber gasket.
I have been trying to learn something about the Overlander side glass and I believe it is actually larger in size then what the postal cut area allows. Looking at your photos below I see a double recess in the window area you cut out. I'm wondering if cutting out around the edge of the outer recess is what was done on the Overlander? This would leave a gap between the inner and outer body though but maybe the window in the Overlander was designed to work with that? Anyone have any good photos of the Overlander interior that shows how it was formed around the windows?
There's some photos in this thread showing what I mean as far as windoow size.
https://www.cj-8.com/forum/showthread.php?t=25857
I had my glass custom-cut at a local auto glass place.
There are a number of manufacturers who will do "one off" special windows, I think these guys are one: http://www.motionwindows.com/
That's true, the Overlander windows are larger than what the Postal side panels are stamped for. I think you'll find that the Overlander has different inside panels for the sides. Maybe someone with a "real" Overlander could post some photos...
Here's the only decent photo I could find of the inside of an Overlander panel:
attachment.php
If there's some specific photo you need of the inside of my postal top with windows, speak now, because within about two weeks I won't have it any more.
Cool thanks! Been looking at there site and the possibilities are endless! I'm trying to visualize my blue 84 CJ8 with a black Postal top and a slider of some type. Maybe a van type with the lower four inches or so solid and top sliders. Wonder if it would be worth it to have the sides racked slightly to match the front and rear angles of the side panels like some of your Safari renderings?
I'm thinking I could cut in any shape I wanted if I were to fabricate a filler piece for between the inner and outer body panels. Looks like the moldings used by motion windows can be had for any where from 1/8" wall to 2" so I could trim it out on the inside pretty easy too.
widows
I made the rough cut on my postal top windows two months ago when I was home, I will be looking in our local area for glass when I come back in 95 days. So You can look at mine or Mark's Postals for ideas
You have any photos of that or a thread link? Can't seem to find it...
Have a look at this side shot from Jeff's Overlander build page...
forum
Is it me or is there a faint outline on the outer skin about the size of an Overlander window? I wonder if the Overlander window went in along that line? maybe the interior structures were formed to support all the van style sides in all of these tops not just postals to keep it from flexing.
That was just a color difference in the paint that was on there when I got it. I don't know what caused it.
Excuse the interuption...
Could you guys give a brief outline of what makes Postals, Overlanders, and regular old 8s different please? Mine has a full hard top and I kinda like to think of it as a poor mans expo rig...Even if the cool name (Overlander) was taken...:thumbsup:
What they all share in common is a factory full metal "World Cab" hardtop, which was designed to be shipped "knocked down" and assembled in the country of destination. It was designed to help Jeep better compete with Land Rover. In most countries where the World Cab was offered for sale, longitudinal "troop style" seating was offered as an option. World Cabs were never generally offered for sale to the public in the US.
"Overlander" was the name used to market the RHD vehicles shipped to Australia. They have a larger side window with a rear quarter window that opens out. The rear "barn door" door hinges on the right.
"Alaskan Postals" were purchased by the Post Office for use in Alaska. They have a windowless "van" version of the World Cab and are also RHD. The rear barn door hinges on the left.
"Llanero" was the name used for both CJ-7 and CJ-8 hardtop Jeeps manufactured in Venezuela. Prior to 1984, the Llaneros had a different type of hardtop, but in 1984 and continuing through the YJ years, they had the metal "World Cab". The World Cab was made in both CJ-7 and CJ-8 lengths, and the CJ-7 length is common only in Venezuela, extremely rare everywhere else.
"Safari Hard Top" was a name used to attempt to market Jeeps with World Cabs in the UK according to a UK sales brochure I have in my collection. I don't think they were very successful, I have only found evidence of one World Cab in the UK (it was a CJ-7 World Cab, and I bought it and brought it back to the US)
Here's one brochure illustrating the World Cab, this has the "Overlander style" side windows, and it is RHD, although it is being marketed in this brochure as the CJ-8 Wagon and Van, not the Overlander:
