jscherb
- Elmira
- NY
Our newest Alaskan Postal owner on this board sent me an email asking for advice on how to put side windows in the hardtop, so I thought rather than sending the info to him privately as long as I'm writing it up I'll post it here in case someone else needs it now or in the future.
This will be in two posts because of the 3-photo limit per post.
In the first photo below you see the inside of the side panel of an Alaskan Postal hardtop. Most of the insulating foam has been removed but there's still some to go. You can see a recessed section on the inside panel; we'll use that for the window. The only problem is that horizontal bar across the window space, if we just cut that out the rubber window molding won't fit properly where it has been cut out.
To solve this, cut the bar out on the lines as shown, and the cut a patch out of the removed bar as shown below.
Continued in next post.
Jeff
Jeff
