350 chevy install-tricks or tips
phil-57
jackson
mi
:cheers:installing 350 with 350 tranny-using 300 transfer case in my 83 cj8 banghead:ALL TIPS-TRICKS-SECRETES AND INFO WOULD BE GREATLY APPRECIATED-THANKS PHIL
Place the motor with your headers on it before burning in the mounts. The steering shaft and possibly the power steering pulley can rub the headers. Watch for the routing of the exhaust above the front axle yolk. Under compression the yolk could come up and smack it shut. I also prefer a good trans cooler in front of the radiator not using the one in the radiator.
I did my swap in 1987, so if I had any good secrets, I probably forgot them by now. Anyway, I used Novak Enterprises motor mounts and trans adapter, and I stuck with the stock 300 and T-176. I did not use headers, I went with regular Chevy exhaust manifolds and they fit just fine. Needed to make the clutch linkage - kind of a simple Z-bar that I am still using today. I originally used my stock radiator, but I had a rad shop switch the outlets from one side to the other.
I'm now on my second SBC, but the hardware I used for the swap is still in place and holding up well.
I copied this out of one of my old posts to Stouttrout-
Ok...I grabbed my folder of notes...(I wish I was that neat...I copied the numbers off the box labels I stuck on the garage wall)! So...here goes. If you have any q's, let me know. Oh, and to let you know what I started with, it was an 82 GM "Iron Duke" 151 4 cylinder, with a T-176 trans, and a 4" lift.
1. Motor mounts- M.O.R.E
2. Headers- Hedman "Tight Tubes"
3. Radiator- from Tellico 4X4, about $189.95, works fine.
4. Hoses- Napa # 7470 and #7575. Not sure which is for the top or the bottom, I do remember the bottom had to be trimmed at one end.
5. Power steering hoses- I had Napa make up some compression Fitting splices to fit two hoses together. Works great.
6. I used a stock long water pump with a stock fan clutch, stock fan, and a Commando V-8 shroud. (a cj V-8 shroud should work too).
7. The stock bellhousing fit the Chev 350 motor, find an "iron duke" bellhousing for your swap.
8. Use a 153 tooth flywheel, a diaphragm pressure plate Napa CA1897, and a Napa RCF 556 10.5" disc. This is the combo for the T-176. Use the stock 82 T-176 throwout bearing, and keep the stock hydraulic clutch setup. You will need to file one of the slave cylinder mounting bolts to clear the oil filter, you'll see...
9. The trans mount is attached to a plate which cantalievers the mount backwards. Reverse this setup, you will need to drill new holes in the skid, but they will be on a level area. Again, you'll see.
10.The rear driveshaft is ok with a 4" lift. The front is extended a little too long, but I haven't overflexed it to pull out (yet).
11.The GM hei distributor needs a strong 12v power feed, one of the existing wires will work. Also the temp and oil pressure senders on my 350 were compatible with the stock gauges.
12.I got rid of all the other wires...I hate clutter. Oh, and I used the stock "iron duke" starter...and it cranks the 350 with authority. The GM starter has a built in solenoid, so you can loose the external starter relay and associated wiring. Positive cable to the batt terminal on the starter and the "hot in start" wire to the ign terminal on the starter.
13.I used a stock mechanical GM fuel pump, and capped the tank vent hose.
14.For a daily driver manual trans, the T-176 trans is ok...a little slow between shifts, the 350 builds revs fast. I like the T-176 mostly because I cant justify the $$$ for a NV4500. I am going to a 700R4, I want overdrive with my new 4.56 gears, and my scrambler is a daily driver (50 mi/day) and I am getting too old getting tired of shifting. The TH350 is a great trans too...but with either auto there are going to be clearance problems along the right side of the pan.
15.Everything else seemed to fall into place...but every swap is different. Good Luck!
Randy....
That is BEAUTIFUL information!!!!!!
You da' man! :bow:
Gary
I'll try to put up any headaches I run into-the real mechanic on this project is my cousin skip brown -he has built 4 or 5 over the years
Chevy smallblock conversion veterans....
I am not at the point yet of swinging in my new motor....I still need to get my tub off the frame, soda blast and paint the frame, install my lift, rebuild the T-176, etc.
However, I got to thinking:
* I have the SBC motor mounts from Novak. They appear VERY adjustable.
* With the adjustability being so large, what tells a fella exactly where the new mounts need
to be placed (with regard to how far forward/backward)?
* This is probably one of those 'you'll know it when you get to it' questions, but?
* Maybe the transfer case and/or the T-176 tranny will also dictate placement?
* Did I read somewhere that the floorboard opening for the trans shifter and transfer case
shifter will need to be enlarged?
Just wondering out loud. Thanks for any ideas.
Gary
I'm running a '70 SBC, with the stock T5 trans/D300 combo behind it.
External Hydro clutch.
It currently has crappy shorty block hugger headers on it but I am replacing them with '65 Corvette 327 'Rams Horn' style exhaust manifolds (2.5" outlet reproductions) to have better clearence to the steering and such.
I am also running a stock GM HEI ignition setup with the power wire being switched with a selonoid directly off the batery to maximize the power to the HEI disty.
Depending on the fan you will need a minimum of 2" of clearence to the radiator, if not more, to avaoid the fan flexing and hitting the radiator.
the shifters on mine ended up in the stock positions in the tub, but I will be swaping in my NV4500/divorced D300 soon and then I will have to modify the tunnel a bit and the access cover as well.
other than those few things...its a very straight foreward swap. Good luck :thumbsup:
Again, good tips! Thank you.
I got to thinking about this: my tub is off. What if I started from the front and mocked everything up working toward the rear? In other words, the grill and radiator will be in their given spot. There's really no other option, since they bolt where they bolt. Then I could mate up the engine, D-300, and T-176. Placing them temporarily behind the radiator about 2.5"....see how everything is sitting, with my Novack mounts C-clamped into place. If it all looks pretty good, I could temporarily drop the tub down onto the frame and see what my firewall clearances look like before I go crazy with welding everything up. Sound like a good plan of action?
I was also a bit disappointed to read about the shorty headers being crappy. I just ordered in a set, thinking that may be my best option....I hope I can make them work, as far as clearances with the steering shaft?
I won't be doing any off-roading- just normal street stuff. Hopefully these mild driving habits will not be a problem for the exhaust, steering, etc. I am basically building what my friends call a 'street baby'. If it were up to them, I'd be hacking out the fenders, building an external rollcage, etc. That used to be my cup of tea, but as I reach my late 40's, I'd rather just cruise the city streets in style :thumbsup:
Thanks for your tips. Keep them coming!
The SB fits nicely in the CJ series frame rails.
Try to get the motor as far forward as possable and as mentioned mock it up before bruning the mounts in. If you are doing an auto tranny move the motor to the drivers side a tad to help with front drive shaft to trans pan clearance.
No auto..
I am running a T-176 4-speed. This helps a little so that I may not need to offset the engine as much?
