Rollbar Tire Mount
Carbine31
Florence
sc
I'm a new member and new owner of an 82 Scrambler. I have searched the forum for a photo of the factory rollbar tire mount. Found lots of conversation about it, but no photo. I particularly would like to see how the mount interacts with the 2 factory holes. Thanks in advance.
Thanks, that helps a lot. Do your mounting bolts go completely through the bracket and bar from the top? I've attached a photo of the top of my rollbar. I do not know if it's stock or been modified, but as you can see, the top of my holes are closed. The bottom has two holes that are open and threaded, but bulge out like it does on the top.
Those are just plugs that are stuck in the factory holes on your roll bar. Stick a long screwdriver in the hole from the bottom and you should be able to knock them out very easily. My roll bar had these plastic plugs, too, due to the fact that my CJ-8 originally had the swing away tire carrier on the back end. I dont remember if the bottom of my holes were threaded, I dont think they are:shrug: The roll bar mount simply slides over the roll bar, two bolts then go through the mount, roll bar, then the bottom of the mount, secure with nuts at the bottom:thumbsup:
PIC
https://www.cj-8.com/forum/attachment.php?attachmentid=15145&d=1258385502
Thanks for your input, that certainly cleared things up for me. Last question. Where did you get your mount?
So I don't want to hijack this thread, but I was wondering if the roll bar mounted spare takes up room used by the back seat if I use it? I am trying to determine where I mount my spare.
It doesn't project that far into the tub to interfere with mounting a rear seat, but the person sitting on the drivers side in the rear seat would be sitting right next to a tire with no outside view from the jeep:confused: It would basically suck for that person:confused:
The mount that is pictured on my green scrambler I bought as a NOS item off ebay. You can find them on ebay, craigslist, this site, etc. My project scrambler had one on it when I bought it, but I sold it to another member here. Prices probably between $100-$300:shrug:
If you are not worried about it being factory...i will make you one that is stronger for $50 plus shipping
Pm if interrested
Pm if interrested
yeah, and you'll make it where it will hold a tire bigger than the 28" spare that came on that factory mount too, right?
To the OP, if you get an original spare mount for your rollbar, I know that a 30x9.50x15 on a stock wheel will NOT mount. You're stuck using a doughnut size spare.
Several of us had to have Scott make a plate that spaces the wheel out away from the rollbar so we could mount our full sized spares.
To the OP, if you get an original spare mount for your roll bar, I know that a 30x9.50x15 on a stock wheel will NOT mount. You're stuck using a doughnut size spare.
Several of us had to have Scott make a plate that spaces the wheel out away from the roll bar so we could mount our full sized spares.
I have the original Goodyear Wrangler H78 - 15LT mounted on a factory rim on the factory roll bar spare tire mount and it fits fine. Not much room between the 1/2 hardtop and the tire tread but it fits. I think it measures 29.6 inches, so a 30" tire would be the biggest you could fit on a factory carrier.
Not an issue of height, but width. With a 30x9.50 BFG MT the sidewall of the tire won't allow the wheel to go up on the spare mount (using a white spoke wheel). The sidewall of the tire would be up against the rollbar and the studs were 2-3 inches away from the hub of the wheel. Might be able to get a wheel with different backspacing, but with a factory wheel and 30x9.50 it was a no go. Had scott make me a spacer to push the wheel a couple of inches away from the roll bar and it mounts fine now.
I gotcha now:cheers: I was more concerned about the OD, but the width is important, too. Went back and found another pic of mine, factory rim with factory spare (maybe 8" wide) and it is very close to the roll bar:eek:
https://www.cj-8.com/forum/attachment.php?attachmentid=15137&d=1258385373
If anyone's interested in an EXCELLENT-condition OEM rollbar tire mount, contact BOBCAT (Don). He has a really nice one available. I saw it in-person a little over a month ago, and have never seen an unrestored one that clean.
Craig
