Need a little prayer
Continue to give your dad something to get out of bed for in the morning............for we all need it, regardless of our age, health, or position in life. And enjoy your time spent with him, doesn't matter at what point it happens between a father and son - it lives in the mind and changes both forever.
Thanks guys for your positive energy/prayers.
drscanman its a 200
An update on my dad. He is still VERY positive and doing very well. He came by to see his pony and was very excited to see where it sits and how its moving (granted I wish I could move faster on it).
But he is currently sitting in the hospital awaiting his 3rd round of chemo and only 2 more to go.
So here is an update on the car. The headliner is in GREAT shape and from what I can tell unlike the rest of the interior(that has either been painted or dyed black) it was origionally black. The only issue was some mold/mildew on it(just surface from what I can tell).
So I cleaned it with a toothbrush and got it about 80% clean on the first round and the odor is now gone. I will do it again one more time and pay close attention to the few spots left behind.
I got the exhaust manifold all cleaned up and it was a task--thank god for files lol. The metal portion of the gasket had rusted to the manifold side and I had to file it off every post but it turned out better than I thought it would. Hopefully it don't leak.
All bolted down with new bolts(and anti-sieze on all the bolts just in case,lol)
I still have to get the exhaust pipe fixed/portion replaced where it mates to the manifold. My dad said he thinks he bought some exhaust parts for the car a number of years ago. He is going to look thru his stuff to see before I look at fixing it.
I went and pulled the carb off to clean it out. Doesn't look too awfully bad but it still needs cleaned out along with the fuel drained from the fuel tank.
Here are the seats that came out of the car. One thing that was odd that I never noticed was the material is different on the front seats to the rear bench. The new covers we ordered will make them all the same.
So I decided to dig into the rear seats first last night. I started with the upper part of the bench.
Started by removing the cover/padding and inspecting everything. The spring assembly was is decent shape with some rust from moisture.
I found 2 places where the main frame had broken the welds. So I cleaned them and welded it back together and had to do some work to make it all straight but turned out pretty good.
Once done I scraped what rust I could off the frame and then painted it to not only protect it but hold what rust was there to the frame/keep it from flaking off. I also figured it could help with killing any odors (old smells).
The padding was in great shape still and I spayed it down to kill any odors as well. This old stuff is certainly allot different than what we use in the industry these days.
The next part made me VERY nervouse. I am by no means an upolstery guy and I had second thoughts about doing the seats. But I know my dad would be happier if I did them vs. somebody else. So I dug in and I think I did a faily good job on my first seat.
So I got the cover off the bottom bench seat and thats where I made it last night.
Well the bottom was certainly harder and I was even more nervous doing it,lol. The lower frame was is perfect shape/nothing broken like the top frame. But I was able to get a great fitment on the cover.
So now time to dig into the drivers front seat. These will need more work to get them right but I hopefully should be able to pull it off.
Ok so I was informed we have hit just about the 2 week mark for the car to head to the bodyman for the body work/paint. So we have in our stash a new hood, both rear quarters, replacement decklid, filler panel between the rear window/deck lid and my dad got a pair of doors (thanks for the link tony).
So I am shifting up a gear or 2 to get it ready.
So I was wrong I started with the passenger front seat--doh..
So I got the seat back all stripped and frame cleaned and painted. Besides the rust it was in great shape.
The cushion was also in really good shape. To pull the seat face around inward around the material seam they use wire thats looped around a seam on the inside of the cover. I had to sand the wire smooth and it was still tough to work it into the new cover.
And here is how the seat back turned out. I was pretty happy with the outcome and I think I got it pulled just right.
I got the seat base stripped down. The shop looks like a war zone with pieces of hop ring clips everywhere,lol...
Can you tell which one the new one is,lol. The drivers side was broken so we ordered a new one.
So I changed gears and decided to get back to the floor since I need to get that done and sealed up.
Here was one of the damaged areas for the drivers seat mount(LH rear).
All fixed up.
The Rh front
All fixed up
The only access on the back side was like 1 1/2" thru hole under the car since the seat basicly sit on a riser off the floor. I ended up bringing my air hammer home from work and working the sheetmetal back up into place/working it flat and welding it up.
And now some fun REALLY begins. You have to remember I am used to removing sheet metal and not putting it back--lol.. So this should be interesting and entertaining.
Here is the start of the mess---flinstone mobile...
And here is where I got tonight with it. With the understructure of the car and the fact the spot welds are kinda hidden by the deep rust its been slow and I have been removing the floor pan in sections.
So its up bright and early and back at it..
So it was another good productive day. And a big thanks to my best friend kyle for coming out and lending a hand taking care of a bunch of small odds/ends--thanks bud..
So I continued to cut away at the floor to where I got rid of the natsy nasty.. But here is the floor with 99% of the material removed that is going to be.
Here is the new floor pan. Its a bit different than whats on the car in 2 places. There is a panel for the firewall that overlaps the floor pan and on the far left front corner the pan reverses how its spot welded on the rocker. This was not a big deal but made it a bit trickier.
I had kyle pull the rear driveshaft so I could replace the rear u-joint. I am amazed at how tiny they are (seen bigger joints on steering shafts,lol).
New u-joint in and kyle threw the driveshaft back in.
Here is the floor all prepped and ready for the new pan.
It took some time but I got the new pan trimmed to where I wanted along with all the holes drilled for all the plug welds to the frame support assembly and the rocker. I ended up going with about 1/8-3/16" overlap on the panel.
Kyle washed the wheels and painted them up for me. My dad is going to love them white walls (yuk,lol)..
So its time to make some smoke.... I started by welding the plug welds as I worked it into the postion then fully welded all the way around it. Once that was done I also fully welded the bottom side--lots of smoke,lol..
But here is how it turned out. The was my very first floor pan I have ever done and I think I did a pretty decent job. If anything its really strong and thats the main thing.
Once done I painted the underside and then undercoated it for full protection.
So I have been putting in late nights to try and make one last hard push on this thing.
One thing I told my dad I wanted to do was the engine bay(looks just AWFULL) and redo the wiring in crashfab form.
Here is the whole wiring mess--dang old cars were so simple.
Here is the engine bay with all removed items than I plan on removing(shock towers, cross supports, brake master,battery tray and brake lines). The shock towers were a pain due to the bolts spinning and I had to cut the brake lines to get them off the ends(rust).
So I am just busting along. One thing I do know is the fact I won't be happy with how the engine bay will turn out. Many know of how I am a perfectionist but this time I have to limit myself. The one and only way for me to get what I would like to do would mean more than we have time for. So I am just shooting for it to look allot better.
So I have been working away and removing rust and some paint/goop. But its coming along.
Here is the lip that I spent some time on. I totaly removed all the VERY hard body seam sealer because I was very certain there was some rust there. And yup there was. So what I did just cut the lip down to where all 3 sections (Cowl cover,lower cowl and firewall) were even and I could get into the seam and kill what rust I could.
At that point once I kill what rust I can I will rebuild a water troft so the water runs down the cowl and not over and into the seam. I figure thats going to be my best option.
