Need a little prayer
Crash, my heart and my prayers go out to you and your Dad and family.
Thank you guys as it means alot..........
So tonight while Don stripped parts off the body my main thing was to start going over the wiring and trying to get it to start.
The stock fuse panel was just sitting and hanging--and its badly rusted out so I am going to replace it with an updated panel.
I threw a backup battery in it to just see if I could get it to turn over--nothing. I was not getting a crank signal to the relay. I started back tracing and was trying to see if I was getting voltage out of the ignition switch.
Well when I was "barely" touching the back side of the switch this happened.
I looked it over and thought to myself--I can fix this. So I cleaned it up/greased it and reassembed it and staked it back together--just like new.
So I threw it back in and it now turns over but won't fire. I pulled the cap off and cleaned the crud off the points and the damn thing fired off and ran pretty decent. While I was doing this my sister called my dad so he could hear it run---he was excited.
One cool thing we learned tonight---as soon as its done they are taking it to california to drive down route 66. So on top of the fact my dad is going to beat this--they have a plan for it...
We are cruising right along. My dad came over on friday to see it and he was amazed with what we had so far. He really wanted to hear it run "thats damn nice"--I told him "not good enough" "thumbsup"
So my brother in law Don is taking care of the body and I am doing the rest--since he is better suited for that and--I am not a body guy.
I got it on jack stands to asses the brakes and such.
I got the interior all wire wheeled. Its not perfect but with the time we are working with--we are just going to have to seal it up the best we can without replacing any panels.
The drivers floor pan has some small holes but its still pretty solid. We will just have to seal it up for now.
One thing I am going to fix are the holes for the drivers seat where it mounts to the floor. The drivers seat base had broke and caused this.
crash, this just proves the extent of your awesomeocity, not only that you'd do this for your dad, but you make a build thread with your typical level of detail and photos on here :bow: :bow: :bow:
That is just the coolest thing I've ever heard... how amazingly sweet :thumbsup: :cool: :D
So awesome...that you inspired Eric to go create a new word. :rotfl:
Of course not.
Just amazed at your vocabularizationisms.
Prayers to your family. Praying both that your father has a miracle recovery and that we get to see a photo on here of him driving that mustang. Keep up the information and restoration photo's, but do not forget to also spend time with your father and family as we all should.
thanks for the good laugh guys [Bawesomeocity][/B]
My dad went to the hospital yesterday to start his road to recovery.
We hadn't told my 2 kids yet (12/14) due to one being gone. So last night we had to sit them down and tell them the news---it was a hard night. Afterwards I had to leave and go into the shop to get my head back on track....
So we are trucking along.
I got the brakes done. I didn't replace the shoes(sanded them) but I did replace the front wheel cylinders. I also repacked the front wheel bearings and turned the drums.
I threw some paint on the drums.
I was kinda scared of this one since it looked pretty rusted and looked like it had never been touched in a long time.
The bolts actually came out with no issue. But I was right it had not been touched in a very long time--the fluid was the blackest 90w I had ever seen but it was not burnt smelling.
Cleaned the heck out of the diff and cleaned the cover and no prodject of mine is never complete without the use of hammerite hammered paint.
I finally got the correct vacuum advance. I totaly dissassembled the distributor, polished all needed parts and reassembled it with the new vacuum advance/points and now it works like it should.
Got it reinstalled and set the timing to spec. I didn't set the dwell yet as I will do that after I get the carb off and rebuilt. This vacuum advance used hardline (3/16 brakeline) to go the carb. Long ago it was cut off so I am going to remake a new one and make it look factory again.
There are small freeze plugs just below the headgasket level on the block. Now I would not mind this but its behind the exhaust manifold and looking at the bolts for it--ya I didn't have a good feeling about pulling it.
So I did everything I could to be gentle with the bolts. I did get it off.
I did end up having 3 bolts brake. One near the center and both upper outer ones(one front/one rear).
Now you can see them very nicely. I am going to just go ahead and replace all the freeze plugs since I will have full access to them.
Now onto the fun part--removing the broken bolts. Luckily I have alot of experiance doing this since I have been in the biz for 20 years. The center one was easy. I just grabbed my torch with a rosebud tip and got the bolt cherry red. After that I grabbed vice grips and you justshock the bolt back/forth and it cracked loose and came out. The others were a bit more fun. Since they were on the outer edges you could see the top of the bolt but I had to remove the valve cover (which I was going to anyways to repaint it), the rocker assy and the outer valve springs. With this I was able to drill into the top of the bolt.
I first tried using my slick extractor. These things were in there and it busted it off. With this style you need to drill all the way thru the bolt which I did so removing the broken piece was easy.
I ended up having to just drill the bolts out completely and run a tap down the hole to remove the rest and yes they were virtually rusted in place.
I had mentioned earlier that there was an exhaust leak at the pipe to manifold area and I was going to drop the exhaust anyways. Well I found out why it was getting worse. The pipe/lip that the donut sits in is 1/3 gone.
I will have to see if I can locate a replacement.
So my brother in law Don has been busting butt on the body and my other brother in law Jason has come over and also helped a bunch with stripping the body.
So Don's buddy came over tonight who is going to do the body work to get another look at the car. He last saw it with my dad some time ago when it was at my sisters. So we went over what needs to be done/roughly.
As it sits we will need to replace both doors due to bad rust on the inside/bottom of the doors. The rear panel behind the rear window/truck will also need replaced so weds we are going to pull the rear window. He also wants to replace the drivers side rear complete quarter and the lower portion of passenger side rear panel. This is all due to rust.
So he said we about a month out from sending it to him.
Go crash (and crash bros-in-law) go!
We be truckin along :smokin:
So my dad stopped by work today to visit on his way to the fair and clued him into where we are and what the body guy said--should have seen him his face lit up with where we are and whats next--pretty cool.. Plus he said something that really sunk in "I am glad its being done but even happier its you thats handling/doing it". We had talked many years ago about this prodject but you all know how things go, get put off and so on. I was pretty proud my dad really looked up to me and I know he's proud of what/who I am...
You can tell he gets winded easily but nothing but positive coming off him--loved that.
So for the last few years he has been the offical photographer for the evergreen state fair and they really wanted him to do it again this year. He agreed and they got him a golf cart to buzz around the fair grounds in. I know my mom is worried he might overdo himself but I think its great he's doing it. It will help him alot, keep his mind off things and remind him he's going to beat this and carry on with his normal routines. He is also a people person who is highly respected amoung his peers and friends..
But we will continue to poke thru this thing to meet our deadline to have our part 100% done when its ready for me to load onto my trailer and haul it off for the body/paint work.
Just an update on my dad. He started his second round of chemo today. His blood work looks really good and his doctor is impressed with his good spirits. After that he went back to the fair and took pictures till 8pm... He's doing very well....
Here is an update. After Don's buddy who is going to do the body/paint work looked it over don went and pulled the doors off because they are no good. At that point don started stripping more areas that we could not get on the body with the doors on.
The door shell itself is toast--just too much rust in them to try and repair them. So now we are on the hunt for a good replacement set and they also reproduce them but are kinda spendy so we are trying to figure out what to do there.
I got the freeze plugs popped out. The lower 5 were not in too bad of shape and didn't pop thru when I knocked them out. The top 4 smaller ones were just toast as every one I popped a hole in it removing.
Unfortunately I had one small one turn installing(they were very difficult to do) so I will have to grab another one tommorow. But the rest are in/done.
I got his new tires mounted and ballanced at work today. I just gotta clean them up so you can see the white walls (what he wanted).
Crash, Prayers for your father have been and will continue to be sent. FWIW, I know a thing or two about cancer prayers. I'm a cancer survivor. Best regards to all of you.
Bill
_______________
'81 CJ-8 SL
'83 CJ-7 Renegade
'98 XJ Classic
