adding more toys to the jeep
RJCJ-8
Rome
GA
I had a productive weekend, did not get to go wheeling but added some more toys to the 8. I added an York compressor for on board air and a rack that goes from the windshield to the roll bar for mounting a CB and my GPS. While I was adding the air I rigged up an air hose so that I could air up or down 2 tires at the same time.... :D
For the York setup i used the compressor mounting kit from Kilby enterprises. It was not as bolt on as i would have liked but it did go on fairly easy with a few adjustments, :confused: mainly to the mounting bracket for the compressors idler pulley. I had to grind some of it down to clear my AL valve cover. I still have some things to add to the function of the compress such as an air tank but for the basic functionality it is great to be able to air up my tires with out having to plug $5 into one of those coin operated gas station compressors that takes forever :mad:
Looking forward to getting to properly use the new toys the first of October, due to scheduling issues and the closeness of Tellico I'll e attending the Dixie run instead of the Fall Scramble but will be looking forward to a large crowd Scramblers at the Spring Scramble. :D
I'll 2nd Boomer, get the Pic's up, I am in the process of gathering parts any pic's would help
