Main relay done. I fused(fusable link) every power circuit. One thing that I have noticed one thing that was lacking.
And down to the alternator.
So the only thing left in the wiring is at the ignition coil, both battery cables, main ground and starter cable.
My dad had been watching the webcam everynight and I got a text close to 11:30 and he was in ahh over what was happening--talk about a good feeling.. Ok time for sleep..
So time to lay on my back. I got the new hat put in and its in there solid now.
I got all the un-needed holes in the firewall sealed up
Here is the new firewall mat with needed areas (at least I thought so at this point) cut out.
I chose to slit it in a few spots rather than pull stuff out(steering colum/brace). So once in place I just used some spray adhesive and put it back together. The only hole I had to add was the upper heater hose hole.But thats in and done.
So I had looked at options for upgrading the braking ability and talked it over with my dad. For now we are just going with stock stuff and before there big trip next year down Route 66 we will look at some upgrades(disk brakes). So for now will be stock. But I got the new master cylinder installed and line from the master to the Tee made.
So tommorow if all goes as planned I will have the system bled/brakes adjusted and tires on and back on the ground.
So one thing that was bugging me was the fact that the interior was going to be new but yet the dash looks AWFULL!!!!!! The black paint is peeling to show the blue underneath it. Well come to find out to install the new defront ducts I have to pull the pad off the metal dash. SO I gently worked it off--and it was a slow process to get it off but I was able to with no damage to it. I did find its in EXCELENT shape. I also found there are 4 studs on the backside that has no nuts on them--so that will be fixed when installed.
And after more work I was able to totaly strip everything off the face of the dash that needs to be removed for paint. So I got a start on sanding it last night before I ran out of steam and will attack it again when I get home.
Made progress this evening (damn work cut into it). But my finger tips are sore as there are allot more little edges to sand down. Just the steering column, very underside and the edges of the dash to do and its ready to go to the next step.
Well it was up early after a short nap,lol. Well I looked at seeing how to get the steering column out of the way--and figured it out. Its more a steering tube than a column. So I got the last of the dash stuff sanded down. Once I got that done I happen to look up--and damn the A-pillar looks just as bad. So that too got sanded down up to the cover piece where the headliner starts.
So now its all taped/masked and prepped.
All primered up.
And painted. I am really happy with how it turned out. Its going to make a HUGE difference on how the interior is going to look.
A pillar.
I dissassembed the steering tube and cleaned it all up. Greased the upper bearing, turn pivat and cleaned the turn signal switch. Primed and painted that as well.
Perfect timing as I am totaly exhausted and need to catch up on sleep and back to it early in the AM..
The coil bracket was--you guessed it--rusty,lol. So I grabbed a new one.
So I put in the new temp sensor and coil and finished up the wiring there--so thats DONE!
I pulled the drain plug on the fuel tank and drained the 6 year old fuel from the tank. It of course smelled old but looked incredably good. Once done I finished up the fuel line from the car to the pump--this is much better than it was.
So I had a problem after I put the brake master in but chose to ignore it and press on with other things. It was time to go back to it. After I got the master installed and the new hardline made from the master to the 4 way TEE---well when I was tightening one of the new lines there went the damn threads. That was one of the lines that was near impossable to remove so I figure thats what damaged it.
So I had looked around and there was no listing at my parts store I use (good place and knowledgeable folks). Ok I am under the gun and got an idea.
Here is what I came up with.
When I tried to install it I chose one little change on the main feed line. All I had to do was bend 2 lines slightly to make it work.
So once I got to that point I bled the whole system with only a couple small easily fixable leaks(some times you gotta crack a line and reseat it). Once done I adjusted the drums--Another thing DONE!!!!!
So putting right along. I got the heater hoses done except hooking them up to the heater core and sealing them to the body. Waiting for the defroster duct assembly to show up--will need the extra room to install it and the heater hoses will be in the way once they are hooked to the heater core.
I went ahead and tore down the cluster and inspected what I could. Ya you can certainly tell its old but you can now see the guages with the lense clean,lol
So I installed the dash pad and this time with all 4 studs and all 8 screws and it fits MUCH better now than it did before. I also installed the wiper switch and new headlamp switch along with the ignition switch and cig lighter. All the bezel pieces were worked over with mothers polish--they really look nice.
I also gave this some polish love and I was impressed with how well it turned out--looks gooood.
So I threw the cluster back in along with the steering tube/steering wheel. I am getting closer and it looks sharp now. Dad is going to love this..
