my 8 is beating me...
Bushmaster6
the Springs
CO
So, a momentous occassion in the last week.. after five years of ownership, (those five years included three PCS moves: TX-CO-FL, two tours of Iraq, three home purchases, one new wife and one son, and alot of other work) and alot of fairly heavy projects (all new suspension, brakes, steering links, ball joints, motor mounts, rear main seal, valve cover, painless wiring harness, clutch/flywheel, MC2150 kit install, rebuilt T5 trans, body lift, etc etc that you can read in my dated "restomod" thread under the restorations forum here)... I put my CJ8 on the road for the first time. :woot:
For that matter, I've driven it to/from work the last three work days. I was pretty excited about this but.. it hasn't been fun. Mostly it's been painful. :banghead:
I knew I have dozens of "bugs" to keep working out, and that after so many years of sitting in my garage/storage, that other issues would pop up during these "shakedown cruises" but, I'm at a point where this is not fun.
Among other issues, I've got a metallic high pitch whine that increases at speed when the trans is in gear... some basic listening and reading Moses Ludel leads me to believe that my pilot bushing (which I installed when I did the trans rebuild/clutch install) is bad.. may have installed it wrong or failed to lube it properly, I don't know... if it's not the pilot bushing it may be the throwout bearing, but I doubt it, and for tonight, I don't care as, either way, this means another weekend, another bunch of money on parts, and another chance to remove my drivetrain to get to a part that's as big as a stack of quarters in the HOPE that it fixes THIS problem... maybe.
then I can get on to... intermittent lights inside and outside the truck, other electrical gremlins, an alignment, an exhaust, finding an alternate way to secure the hardtop, new tires, fixing the heat/blower motor so I can actually defrost the windsheild, and a list as long as my arm of "little things", and that's BEFORE I get to the "wants" (rockhard sport cage, full soft top, back seat for junior, cosmetic fixes, etc..)
it only gets worse when I think about the money I've put into this.. bought it at the market peak, paid too much, invested more, and I routinely see Polarfire finds of better/nicer rigs for a percentage of what I've got in mine..
so, as I sat at a traffic light in the rain tonight, writing notes on things I need to fix still, I looked over at a guy in a 1st generation dual cab Tundra 4WD and thought "boy, that's a niiiiice truck".
b-tch session off, ordering parts tomorrow.:cool:
Its not beating you.....Its Love
And why you were thinking that, the Tundra driver was thinking, "Boy, I wish I had a nice old Jeep like that guys instead of this POS inport that looks just like everyone elses...."
Theres something there about grass being green or something like that....:rolleyes:
Never question what you paid for something, you made your decision, live with it and get on with life, learn from it if possable. I have leaned over these many years that looking back does nothing more than frustrate you and get you upset. Live and learn from the decisions you make in life, dont lament them.
I'd look at the bright side:
Your able to drive it!! that means your home alive and healthy and not being shot at. (always a plus)
You have a Wife and Child that Love you, really that is what this thing called life is all about, and that alone makes it worth getting out of bed in the morning.
Like many others have said (and not all of them have lived) "its not what you buy but what you build" Your living that now, your building your own, you will know every nut, bolt and weld on it. Belive me, when your done with it, it wont be just a Jeep, but a part of the Family.
Now as for the repair issues:
Did you put oil in the trans and t-case?
The ONLY time the pilot bushing would whine is when the clutch is pushed in while stopped, as thats the only time the input shaft spins at a different speed (zero rpms) than the engine(900+ rpms). If you have noise with this conditions, check the pilot bushing.
With the engine idling and the clutch released, then input shaft is spinning at the same speed as the engine, if you have noise then, start with the throwout bearing and move rearward to the trans input shaft bearing. (again, did you put oil in the trans and t-case?)
By what little you describe, I would guess it only happens when it rolling, You really need to check the oil levels in the trans and t-case.
Good luck with it, Let us know what you find.
and thanks for your work overseas. :usflag:
thanks O for the comments (and the technical feedback).. I was in a bitchy mood last night so I guess I was trolling for sympathy.. I am by NO means a mechanic, so even simple things for the technically inclined are a challenge to me.. and this truck is a never ending challenge for me, to the point of no longer being fun.. trying to knock them out one at a time.. and my Landcruiser (DD) is down for at least a week with a bad radiator and leaky PS pump so, the to-do list ain't getting shorter
what you say about the pilot bushing makes sense to me, but the specific quote from the Jeep bible indicated something else (it's at home, I'm at work so, can't cite it to you).. my specific symptoms:
- no noise when clutch is engaged (I'm stepping on clutch pedal)
- no noise when vehicle is stopped (standing still)
- gradually increasing mechanical whine with an increasingly higher pitch that matches speed.. starts getting noticeable above (about) 25 mph, quite loud at 45-50 mph, haven't gone faster than that (speedo no worky, add that to the list)
- pitch doesn't change with each gear, only with increased speed (so I don't think it's individual gears)
- noticeable pitch change and noise when I'm decelerating in gear
- as soon as I step on the clutch, noise goes away
- I have NO noticeable clutch slipping, vibration, chatter
- this noise started the first time I drove it (so it hasn't worsened or lessened in time, it's been constant)
- I do recall the transmission output shaft was difficult to insert into place at reassembly (it took alot of muscle to get the trans seated back in place under the truck, a friend, I assume it to be the point of the shaft barely fitting in the pilot bushing)
I DID change my trans fluid last night before I went home to Pennzoil synchromesh (spent 1/2 an hour yesterday researching that debatable topic before I bought it). Even though I paid to have the T5 rebuilt 5 years ago, it only has about 60 miles on it since then, as it's never been on the road. REbuilder told me to change fluid at 500 miles. I had no idea what the fluid level was so I changed it anyway... with fingers crossed that it was the "simplest solution first", and it made no difference.
I DID NOT change or check my xfer case fluid. Unit was not rebuilt, and the noise seems to be coming from more forward in the driveline (best I can approximate while driving).
:shrug:
It's not just a Jeep, it's an Indenture! Sorry, I just had to paraphrase the Navy slogan from back during my service years.
I can feel you pain. After a 17 post-purchase hour shakedown drive home from Louisville in a beautiful '84 Scrambler, I began the work or sorting out things the weren't quite right, were never done, or I just wanted.
Among these in no particular order: leaky front axle seal, leaky diff seals (both), weld in the cat-back, replace u-joints and clamps, alignment, poly body mounts, sun visors, bikini top & windjammer, side steps, washer bottle & pump, stock steering wheel, brake bleeding & speed bleeders, door seals, door panel install fasteners, black stainless hinges, stock front bumper, rear bumperettes and receiver, shaft style radio, front turn signal buckets, headlight buckets, over-bed Thule bars & kayak saddles, window crank handles, door locks and AMC keys for doors & ignition, correct speedo gear, TFI ignition with new distributor & coil, Weber carb tuneup...you get the idea.
Still to go: Nutter bypass, fuel sender/whatever else is wrong there, install underdash courtesy lights, lighter & ashtray, install the rest of my bushing kit, new dash with both speaker cutouts, new fitted carpet, shifter boots...fix whatever goes wrong next :banghead:
I really haven't kept track of the costs. The axle, welding and alignment work was farmed out. The rest happens as need, time, and money allow. The pace dictated by the time and labor involved as most things aren't that expensive. Each chore makes the CJ more my own beast.
And throughout, I've had the "banana wagon" as a preferred daily driver and weekend beach bomber. It's reliable enough to trust, but will always be in need of a tweak here and there. It's the only LEGAL topless pickup on the beach and catches attention often.
attachment.php
So now that your back on home turf, enjoy your family first. As time and cashflow allow, fix and enjoy your Scrambler with your family. By the time your child is ready to drive, you'll have something unique to pass down...but only if you're finished! (hint: there is no finish, there's always just one more thing ;) )
And most of all, thank you for your service to our country.
Bushmaster6:
Like you already know, knowlege is generally something that is hard won, and skills always need to be developed. The more you learn the easier this will all become.
So dont fret too much, at least your willing, thats more than most people in todays society.
On to your Jeep issue:
Let me ask this, you say the noise is speed dependant, is that road speed, engine speed or both?
Also, it goes away when you engage the clutch or your stopped.
(do you mean when the trans is in neutural with the engine running and the clutch released or stopped at a light with the clutch engaged and in gear or while rolling down the road and just pushing in the clutch?)
Right now, with what information you have given, it sounds like the throwout bearing is bad or incorectly installed.
You also mention that it was hard to reinstall and seat the transmision 'output' shaft, (I assume you ment input shaft).
That brings up another possability: the clutch friction plate is installed backwards.
If the friction plate is in backwards, you could be rubbing the nose of the bearing retainer on the cone of the friction plate, it would whine horriably and be speed dependant.
The bearing retainer is the tube that bolts to the face of the transmison that the throwout bearing slides on and the input shaft runs thru.
In any case, you need to start by dropping the transmision and inspecting the end of the bearing retainer, the throwout bearing and then looking at the friction plate cone (thats what the input shaft splines into) and looking for shiney metal/wear marks.
I hope this helps you some, please ask more if you would like help.
Glad you changed the oil in the trans, now you know where its at, its always good to have a solid baseline to start from.
As for the Land cruiser, the radiator is a prety easy fix as you know, and so is the pump, problem is, on a land cruiser, those parts are a little pricey, and on the new body style, if thats what you have, alot harder to get to.....good luck
I'm talking road speed.. faster I'm going, higher the pitch. Noise has no correlation to RPMs nor to what gear I'm in.. I just happen to be in higher gear at higher speed.
As far as neutral vs in-gear but clutch engaged.. both. If I step on the clutch, the noise goes away. If the trans is in neutral or in gear, it goes away. If it's out of gear and I release the clutch, still no noise. Noise only present when I'm in gear, clutch pedal released, and moving (or decelerating). As soon as I push the clutch pedal in, no more noise.
The noise doesn't SOUND like it's coming from far enough back to be xfer case, but the relation to road speed makes me wonder.
Kimsvana.. yeah, it's a labour of love, or it has to be, as it would otherwise make no sense.. just not feeling much "love" right now. Drives like a tractor. The money issue for me at this point is seeing what's now available so cheaply (thanks to current economy) vs what was inflated (when I bought).
As I was underneath it on the lift last night a dude driving a big Chevy off-roader walked by and said "sweet, man".
It's been a while since I was into a transmission, but bearings *inside* the case are also a possibility. Is the whine there in all gears or all gears except 4th. 4th is straight thru the main shaft and leaves the countershaft idle (IIRC). Also since the sound is strictly groundspeed rather than engine rpm dependent it would seem to be more likely in the output end of the tranny.
I try my best to NOT look at prices after I buy most anything...there's ALWAYS a better deal tomorrow.
And that's just the start. I can't begin to tell you how much time has been lost in Jeeptalk since I got the CJ.
whine is present in all gears, including fourth.. in fact it's loudest in 4th and 5th, as those are the gears I'm using at 40+ mph on my commute.
time lost in Jeeptalk.. between this forum and college football Saturdays, I've probably missed an opportunity to actually do someting productive with my life!
That really sounds like the output end of the tranny. Input side varies by rpm but output by mph.
Maybe try shifting the trasfer case to NEUTRAL, start up and run through the gears. If the sounds stays the same, you're into tranny out or tcase in. I'f it goes away, you're tcase out. Might discern more if you got your ears under the cases and had a helper/wife do the "driving" for you.
I'm rusty on tranmissions. Last one I had open was a '53 MGTD in '88. Had to replace a layshaft with a broken tooth. Easiest access is from the top gained by pulling the floorboards (real wood!) and tunnel through the interior. The same interior I had JUST REFURBISHED A WEEK PRIOR!!! :banghead:
I have my wife to thank for letting me yap on a while, then pull me back into whatever I *should* have been doing :)
Good luck!
It could be the rear trans bearing, but i would have hoped that the trans shop had replaced it.
The T-5 transmision 5th gear is on the t-case side of the outputshaft bearing if I remember correctly, so that means it splits the support with the t-case input bearing and runs on a bushing.
It could be that the t-case bearings are shot.
You had the trans rebuilt, and you said it went bad right away, and it was rebuilt under warrenty. Perhaps it did some damage to the t-case or the t-case damaged the trans.
Even though the Dana 300 is fairly quiet for a grear drive t-case, they are still noisey, you will get gear whine, especially in low gear or if the bearings/bushings are worn.
You said that when you push in the clutch the noise goes away. Worn t-case bearings will allow the gears to whine excessively when under load, and stop for the most part when you push in the clutch.
Basically you just need to start poking around and see what you can find.
So do you have a lift available to you still, or are you working on the ground like the rest of us?
I read your build thread..Personally, I dont think you have a bad Cj-8 there, :drool: its nice looking
They are SOOO much worse up here....:banghead:
Good luck with it and dont let it get you down :cheers:
thanks guys... I do appreciate you taking the time to brainstorm this and type out your answers.. I hope I'm not wasting your time with something silly (like low xfer case gear oil), but we shall see..
Orionn, that's a clever idea on "driving it" with xfer case disengaged, wish I'd thought of that earlier. Wouldn't thowout bearing noise be related to actual clutch pedal engagement? My noise is when it's actually in gear...
and the lift is courtesy of your (and my) tax dollars (and user fees), most military bases run an on-base "craft shop", basically a self-service garage when you can rent bay/lift time.. some better than others.. I pay 4 bucks an hour for flat bays, 6 an hour for a lift.. the tools and SAE mechanic advice come with the rental cost... other services (ie: turning brake rotors, sandblasting, etc) cost more.. you can see pics of the facility in my restomod thread..
final thought.. as I'm assembling parts list to order after more troubleshooting tomorrow, is it possible, with the trans bolted in correctly, that the entire unit is still somehow off alignment? ie: could it be bad x-member mount, bent x-member or frame, something like that? the trans is bolted up and torqued on so, not obvious mating problems that I'm aware of...
plan now is to drive it to work tomorrow, change gear oil in xfer case at lunch, road test, and the get it on the lift after work and see if I can isolate the noise with four tires off the ground.. if THAT doesn't work, will have to find a weekend to start pulling it apart again
so.. does THIS confirm my problem??
took Orionn's advice, went outside, started her up, put xfer case in neutral, ran the tranny through all five gears revving it up in each, and not a PEEP out of the trans/clutch.. all I could hear was my motor running (refreshing change)..
so, to this untrained mind that means:
(a) the noise comes from the xfer case, despite what direction my ears tell me
-or-
(b) it's from somewhere else, but the noise requires resistance (rolling resistance) to manifest
any thoughts?
and Randy, the rear axle pinion seal does leak, but only when the fluid level is high enough and the truck is parked downhill (so the pinion is on a downward angle).. I bought a CJ D44 to swap in, just haven't had time for that yet, and never bothered messing with the rear end seal.. but I've towed this truck THOUSANDS of miles with the rear driveshaft disengaged, I'd have figured the read would've completely blown by now if that was a problem.. when I rebuilt the brakes this year, both sides axles turned freely when the truck was lifted..
-or-
any thoughts?
I'd say you've cleared the tranny and input to the tcase.
As a next diag step I'd try raising the rear wheels, shift the tcase into 2High, and repeat the "driving" process. Get under and listen for which end of the driveshaft the sound comes from. That should tell you iif you sound is in the tcase or rear diff. You could then remove a ujoint to isolate to the tcase (if necessary). I suppose the failing ujoints could be added to the noisy suspect list as well.
When towing, did you run the engine every 200 miles to keep the tcase lubed?
I do miss the base auto shop space. You've got great equipment available at a low price AND the expertise and advice of some real gearheads and pros.
So far all you diagnosis has cost is time and labor. Once you're sure where the problems lie, the parts price may not be too bad. And it'll definitely be cheaper than replacing the wrong thing first!
Good Luck!
going to try the wheels-in-air test today, along with simple fluid fill/change in the diff..
the u-joints are "new" (low miles, not by calendar period), changed them when I did the trans removal last time, but doesn't mean they aren't bad, but I get ZERO driveline vibration
as far as towing, I used a dolly, and removed the rear driveshaft, so only the rear wheels/axle were turning, the xfer case wasn't affected by that..
among reasons (other than the apparent source of the sound) that I'm leaning to t-case is: it's the only item I haven't really touch/replaced, and the truck WAS loud from the time I bought it (before any other portion of the driveline was serviced)
yep, the auto shop is a great benefit, only downside is that 90+ percent of the time that it's open is when I'm still at work.. they don't run "reverse hours" for Soldiers.. open til 8 T/W/TH, 4 on F, and 9-4 on weekends.. and closed on holidays (when I'm off work).. so, a good deal for sure, but not always convenient
Sound good. Maybe fluid in the tcase as well?
Ujoints was a SWAG on my part...not likely, but you never know. Your towing was definitely safe, so another SWAG-and-a-miss by me. :)
Sounds like you've got it surrounded. Now go git'er done!
Funny how that works. It's for your use, but not your schedule. I spent years on rotating 2-2-2&80, 2-2-2&32, or 1-1-1&56 rotating shifts. Nobody but the chowhall seemed to support those hours ;)
Bush:
Thanks for the Kudos, but that was Kimsanva's advice (credit where credit is due and all that)
Dont be suprised if driving the wheels while its on the lift doesn't produce the sound (though it may) as your not loading the driveline sufficiently to create
Its sounding more and more like the t-case needs a rebuild.
If you decide to do that, its VERY easy to do if you have a press handy. Theres no need to pay someone to do it for you.
Dont skimp on the t-case rebuild, replace everything, including the intermediate shaft.
I Like Novaks kit they take the care in manufacturing the intermediate shaft so it will last.
Hopefully, all this information hasn't turned your brain to mush :fingerscrossed:
my brain was already mush... results follow
two points for Randy's diagnosis... I'll post the results of what I did over in my restomod thread and resurrect that action...
