Tuffy security box?
Bushmaster6
the Springs
CO
I was looking at the dimensions on the Tuffy "large" rear security box and, if I'm reading it right, it's 27 inches deep and just short of 36 inches wide, which would fit behind a rear fold/tumble seat in the Scrambler...
link to product is HERE
has anyone tried or installed one of these, in a CJ or LJ or other? They are pricey but I've seen a few for sale in national searches of CL..
Crossbones has one in the back of his Scrambler, but I don't think it's the same as the one you posted pictures of. I think his has drawers.
their pickup bed long drawers would be a cool approach to storage/security, but with two little monkeys I need a back seat.. just courious if anyone had pics or opinions after installing one of their products (in the back)
I tried to use their drawers in mine (full length) but the dimensions are not right and the cost is prohibitive for me so I built one. I had planned to get the tuffy used but the guy sold it to someone else when he was waiting for me to come pick it up.... Just as well in my case as it turned out, I think the drawer set up would work behind the seat well though, not so sure about this pictured box though as I think you would find that you couldnt actually use the top door for access you would tend to accumulate stuff on it, so if you can get what you wan tfrom the little door go for it. A friend has one in his YJ and regrets not getting the drawer for that very reason
Will you be using it only occassionally or all the time?
If only occassionally (e.g., the occasional campground camping trip), you could build something quickly out of plywood or 1x wood. Yes, I know, it sounds a bit redneck... but if you're in a campground, no one cares.
I carriage bolted through the wood box's bottom crossmember (or wood box floor) through some existing holes in the Scram bed.
Add some locking clasps from the hardware store and some padlocks and you're all set.
For occasional use, I have a pickup style box, but shorter and made of plastic.
It locks (well let say it will keep honest people honest), and has two rails that attached to the floor. It slips onto the rails and lock locks down.
Not the most secure, but its lightwieght, easily removeable, and really cheap.
All I keep in it anyhow is recovery gear, not of much interest to most people out there.
Just another posibility for you....
another thought, the rubbermade action packers come in a variety of sizes, are inexpensive, and fairly secure if you lock the hasps. Mounting is up to your own creativity but fairly easy even if you just use rachet straps. I use a few of the small ones shen I'm not camping in one spot and they work pretty well keeping my chow edible and my stuff dry. and you an get them anywhere but Wal Mart unfortunately has the best price usually
You might check out the Delta Champion aluminum truck box, (SKU 356002 - Black or SKU 356000 - Bright Aluminum). I think the dimensions are 37" W x 20" D (front to back) x 14-1/2" or 16" High, (weigh about 30 lbs). Amazon has them for under $300, shipped free. (Less than half of the Tuffy.)
This would allow you to use it, (as others have suggested) in you truck, garage or someplace else besides the Jeep when you don't need it.
thanks.. will look them up.. my fenderwells measure 36" apart, almost exactly, at least at the base.. so if the Delta product is 37" that would be a smidge too big
I saw a review of the Tuffy box in one of the 4x4 magazines that said that while the security of the box is great, it is not water tight and not good for leaving open to the elements. As others have said, I think you can find better products with more versatility elsewhere for much much less.
Just my two cents.
I checked the Delta Champion web site. The box base measures 36", the LID measures 37". I think the lid would be above the wheel wells. You can check the specifications at www.deltastorage.com. It is classified as a Champion portable utility chest. It might be a great friction fit on the sides! I think I'll look into using this one in my Jeep.
