Denver/Colorado Emissions Rules
OGRES
Ramblin' Wreck
BENEFACTOR
Suwanee
GA
So, I might have a good lead on a job opportunity in Denver and had some questions about the emissions testings and requirements for vehicles in Denver. It looks like they have a pretty strict policy even for older vehicles. My '82 scram doesn't have a whole lot of emission control items installed on it...like the catalytic converter for instance or the charcoal canister.
What is is going to take for me to pass emission testing to register the scram out there? As of right now, the scram will be my daily driver but eventually I will get something else to drive everyday, but I will still want to drive around in her.
Thanks in advance.
can't speak for Denver, but El Paso county (to the South, where CO Springs is) has none.. and it IS a commuter base to Denver.. just sayin' ;)
The Front Range is quickly turning into California-style emissions. Denver metro is by far the strictest, but Larimer, Boulder, and Weld counties to the north are right behind them. We've had about 6 years of worry-free emissions, but just this past year it's gone full-crazy. I have testing in a month, and I think it really depends on who I get for testing. I might be able to convince them my mufflers are GMC-style cats. After that, they want something that looks stock under the hood, a good sealing gas cap, and a passing sniffer test. I know that Denver metro is way more strict on what they consider "stock-looking," but for now we've got a bunch of untrained monkeys looking under our hood since the laws just took effect. Expect El Paso county to follow suit with Larimer and Weld counties.
Basically, I would say that if you plan on living in the Denver metro area - Adams, Arapahoe, Broomfield, Denver, Douglas, Jefferson counties, you're going to need to go with a TBI set up. That pretty much negates any need for smog pump, EGR, etc. Canister, I'm not to sure of.
Here's my set-up: Clifford 6=8 intake (non-functional, cracked, coolant loop bypassed), MC2150, intact canister and all hoses, valves, etc, dual Clifford headers and exhaust. No O2 sensor, no coolant temp sensor. Team rushed, no need for Nutter since there's no 'puter. I'll let you know if that passes up here, but I doubt it would pass down there.
Good luck on the job opportunity, that's probably the most important thing, though.
Thanks walkerhoundvm...I was hoping that you would reply to this thread and give me some insight. The PO dropped in a 304 with an edlebrock 600 CFM carb and had pretty much all lines removed that weren't necessary. No catalytic converter either so I am sure that I will have to get one of those installed should everything work out with the job.
I am thinking that all of this would be a good thing because it means that I found a job in an area that the wife is wanting to move to...:cheers:
The easiest way to get around is What bushmaster6 was eluding to , register it outside of the emisions area.
I definitely thought about doing that...unfortunately according to the DMV website, even if you live outside of the "emission control area" but commute into an "emmission control area" you are subject to emission testing.
I don't know how strict they are on that, but it makes me worry a bit. If I don't have to drive the scram as a daily driver I think I could get away with this.
They have portable exhaust sniffers. It's a guy, equipment and a truck, who is set up on the side of an entrance ramp, usually. (Ex: they always have one set up on C-470 & Quebec - east bound.) As you drive by - you are accelerating to get up to freeway speeds and the sniffer checks you exhaust. It ignores you if you pass, snaps a picture of your license plate if you fail. Those that fail then get a notice in the mail requesting you bring your vehicle in for a emissions test.
I googled Colorado Emissions Requirements. It looks like a vehicle as old as your Scrambler is only required to pass a visual & idle test. (So the sniffer truck may not flag your vehicle, don't know for sure.)
Who knows, in Colorado you may move next to a tree-hugger who does not like your stinky, smokey exhaust. Then the state will be the least of your worries!, :D
I've known a lot of people who have lived outside of the area and have never had a problem.
Colorado Emissions
If you live in the Denver Metro area, and soon to be the front range which would be from Fort Collins to Colorado Springs all the counties in between you will be required to have an emissions test, Now one way people get away with that, is they have residents in the mountians and other counties that do not require emissions testing. They register their vehicles there.
If you live outside the Denver metro area and are not required to have an emissions test, but drive into the area for a job, lets say you are required to have one, but they have no way of checking each vehicle and really do not enforce that, I have never herd of anyone getting a ticket for that.
What they go by for the emissions equipment on your vehicle, is what the OEM had on the vehicle when new. They go by the emission label that is under the hood, if not there don't worry they have lots of books that tells them. You will need a catalitic converter, some of the other components that you might need is an EGR system, if it requires an injection system and a check engine light if it's fuel injection.
There is a split in years I think 1981 and older only use a static sniffer test and 1982 and newer they use a dyno with a sniffer test. But ther is a house bill that is going thru our local goverment that will require ALL vehicles as far back as 1945 I beleive, to have E-tests.
Since you will be coming from out of state you will need to stop by the Emissions test place and get a VIN varifaction form filled out first runs about $20. E-test run $25 but the good thing is you only need to get one every other year.
Yes you can do engine swaps and alterations to the engine. On both of my CJ8 I put the Howell Fuel Injection system on, that allowed me to remove all the air injection crap from the engine. just have to have the state inspect and they give you a waiver it's free and does not take to long, just have to set up an appointment.
Hope this helps out. Todd
Just a slight modification of Challenger's great collection of info: at least in Larimer county, 81 and older need yearly emissions tests, 82 and younger every other year.
Also, we have the mobile vans up here, too, and from what I've read they monitor who's passed as well (I sure hope so, I keep driving by them on purpose). If you pass, you still get a bill in the mail, but you won't have to go to a testing center.
Last - there is also a doomed push by Larimer and Weld repubs to get rid of the NoCo emissions protocol in favor of every three year assessments on pollutants.
What you'll probably see just by looking through this thread is that these tests are in no way standardized - it seems to be a real crapshoot, at least in Larimer county. I've also heard of guys in the metro area getting tossed out for the Howell kit - then they drive down the road to the next testing center and get passed without an inspection.
Just because of that I'm really considering TBI, if only to never have to worry about it. Of course, as soon as I do they'll drop the requirement. Then a few years later, they'll resurrect it again.
I think if I lived in CO, CA, or any of the other exhaust gas nazi states, I would just put the Mopar MPI kit on a 258 and be done with it. The MPI kit comes with a CARB #, so if it passes CA strict emission tests I would assume it would pass the other states:shrug:
One of the good things about MS, we don't have any of that testing here. Heck, half the people on the road don't even have insurance, and that has been a law on the books for a long time:angry:
Taxes must be high in CA/CO to be able to pay State employees to go around testing emissions on 20+ year old vehicles. I think if i was governor I know where i would cut some "fat" out of the budget first:thumbsup:
Again, thanks everyone for the responses. It sounds like there is a lot of variation in what is enforced and how it is enforced. I will take my chances and see what happens when and if I ever get there.
Well, things have progressed a bit from my original post.
I now have a tentative offer for work out in Denver. I will be flying out there in a few weeks to do a final interview and negociate my package deal.
Looks like I am going to have to figure out what to do with the Scram sooner than later now.
