Another approach
Well there is a school of thought that rust is only delayed.....
However, I saw a frame off restore post for a YJ & when I did my son's YJ frame off, we first got a good frame from a Colorado donor that had a dash fire (got tub too). What this guy did & I emulated was tape all the holes in the frame, then tip one end high & pour in some paint (obviously clean it out first best you can & toss some degreaser in!). Then rotate frame 90 degrees each time until all four inner sides are coated. I caught drippings in a pain under low end. He used hammerite Rustoeum paint. I used POR15 (PRICEY!). When I do the Scrmaber this winder I think I will use an SEM product. The guy I bought the Scramber from does restores & he likes the SEM product better than the POR & after he showed me some applied I think I like it better too. Also slightly cheaper. I paid $150 for a gallon of black POR & still have to top coat cause not UV proof.I know I got a decent inner coating on the YJ because I saw the film covering the holes when I peeled off the tape. BTW, I cheated cause I have an electric hard top hoist I made & used that to put one end up in air. People here like pics (me too!) so I posted some from the YJ project. The last two show the black POR film sealing the holes. It did not really need to be blasted but I had it blasted anyway. The inside of the tub needed blasting but they did both reasonably & I could start fresh. Hope this helps someone else. I liked it so well I will definitely use it on the Scrambler frame. I need to decide to patch metal tub or go fiber glass tub next.... but need to post that in a separate thread in right forum. thnx, Danimal
