My turn!
WillyT
Scramblered
chicagoish
IL
Well, here it goes.
This weekend was pretty nice. Of course, "nice" for other people means "hot" for me, and "hot" for other people means "kill me now" for me. It was a good day to finally start ripping into the 8. I got about 7 hours in today, cut it off since I was A) exhausted and B) ominous clouds were rolling in.
I was surprised at how easily the bolts and screws have come off so far. No heat, no Kroil needed yet.
The basics. Take the doors off. Neither of which close all the way, but that's a problem for re-assembly.
attachment.php
With the halfcab off, I can get whats left of the windshield frame off.
attachment.php
attachment.php
Bye bye windshield!
attachment.php
Attacking the dashboard. The pad came off pretty easily, a couple of the tabs that hold it on to the top of the tub had rusted through. Somebody was nice enough (:rolleyes:) to put in aftermarket speakers and holesaw through the speaker grills. So, that's a new dash along with everything else.
attachment.php
No more gauges! Radio went in the trash. Those HVAC cables are kind of a pain to deal with. Glovebox bin had rotted through pretty bad.
attachment.php
And no more dash!
attachment.php
I thought the bulkheads were supposed to be easily removable? I don't know, this one I had to Sawzall out. There was some sort of sturdy caulk or something holding the sides in against the tub. I didn't even have to cut all the way through, the Sawzall vibrated the glue loose. Couple of swift kicks, and out it came!
attachment.php
I was having some trouble reaching the rollbar bolts, so I figure if it's good enough for the Flintstones....
attachment.php
The bolts were coming out OK, but I was having a problem with access. They'd come out with a breaker bar, but I could shoehorn my breaker bar into the right position to get it turning. A cut-off wheel makes short work of the bolt heads.
attachment.php
wow, I"m exhausted too! good luck with it, are you doing a restoration or a build up?
Both. I'd like to keep the interior as stock as possible.
I'll be putting in a Gen 1 SBC 350 with a 700R4 trans. Keep the Dana 300. Keep the axles the same, but upgrade to 1 piece. Old Man Emu suspension (probably 2.5) with maybe a 1" body lift to accept 32x10.5's. New tub from Willy's Overland.
All of this is probably going to change a few times as the project goes on :crazy:
Looking good! Let me know what parts you are going to be looking for and I will keep my eyes open for it. I know of a good uncut dash panel and I think I know where a good bulkhead is not too far from you.
:popcorn:
Thanks for that. At this point, I think I'm going to be going with all brand new body panels. It's going to be a daily driver, not an offroad rig, so I want it looking sharp as possible :)
FINALLY got this thing indoors! After sitting under a tarp for 11 months and having to deal with 2 feet of snow, 90° days, and all manner of animals and rain, it's under cover.
Pulled the hood off, the seats out, and that's really about it. I decided it would be smarter if I didn't get overzealous with unbolting stuff until I really got into the PDFs I've collected.
My plan right now, if possible, is to take the body off, and then the driveline. Which means the steering column will have to come out, and I need to read up on the proper way to do that.
Taking the seats out, you really get a good idea of just how bad this body is.
Wow, missed this before... those are some rotted floors! Keep up the good work! :popcorn:
boy that looks alot like my 8. I am into about the same maybe just a little bit more rot. Keep up the chin you will be like me discouraged at times but once the parts pile grows you will see the light and then remember you need lights also. :crazy:
the steering column removal is pretty straight forward.. theres a 2-piece bracket on the firewall (bolts on the inside) that you have to remove, and then two bolts that hold a collar looking bracket to the upper dash/cowl area.. inside the engine compartmet is where the upper/lower halves meet at a u-joint.. there is a collar holding them together on a splined end there, and another splined end w/collar where it meets the steering gear box..
it actually took me awhile to figure out where mine split because it was so gummed up and/or corroded, but once I figured it out, a few whack with a BFH separated those collars and allowe me to pull it apart.. a tie rod separator will work around the lower splined end (where it meets the steering gear box)..
if you need pics of all that, check out the reverse proceedings (assembly) that Raymond (Spankrjs) documented in his build thread
:cheers:
So I see you are in Chicagoish as am I. Where did you buy that Scrambler? Was it from an older gentleman in Mukwonago WI? I bought an 83 parts Scrambler from him & he had one that looked just like this in his back yard with a bunch of parts in the rear and a plow on the front. It looks like the same one- just curious. :D :cheers:
Just keep taking parts off & soon there won't be any left to take off.
Then the "fun" begins.....
Thanks guys :cheers: Lots of pics for BW :D
I took a look at the pdfs, steering column looks to be pretty easy, just as bushmaster mentioned. This thing hasn't required much of a BFH...yet...to my surprise, but we'll see what's waiting on the frame :D
Danimal: I bought this off a guy (a member on here, actually) who lives right around Rockford. I don't think it's ever had a plow on it (I hope not). It was a long, slow ride all the way down 72 :rotfl:
I'm right over by O'Hare, maybe about an hour away.
WillyT, You can get the shop Service/repair manuals online in PDF format for free they explain how to take everything apart. Let me know if you need it and can't find it and I can email it to you. I put it on my Ipad so I keep it close by whenever I need it.
Have your researched front driveshaft clearance issues for installing a 700R4 while keeping stock width axles? Plenty of info out there.
Unless you've got some sort of go-around already planned, the trans pan most likely will force you to use a two piece driveshaft. Most of the successful 700R4 installs I have seen were done with full width (full-size truck width) axle swaps.
I could be wrong, though, so let me know if you have found something different about that.
-Mike
I've got the technical service manual, the haynes manual, and a few other random ones. I used to have the printed version of the Haynes but I gave it away when I sold my 7 years ago.
-Mike
I'm not sure how much it matters, but I may not be using the 700R4 anymore. I'm now looking at TH400 since they came in 7s with the Quadra-Trac. That way I can sort of keep in the spirit...kind of...of originality. The 8's never came with a V8, let alone a 360, but that's the updated idea, and it's close enough :D
Actually, it would probably be a good idea to update my plans.
Updates plans, sure to change in the future:
  • Willys-Overland Repli-Tub. OR, if I can find one, an OEM tub that requires a lot less work than mine
  • AMC 360. Got real lucky. Turns out we've got a block laying around that a customer abandoned years ago. It's even got a Summers Brother cam gear drive in it.
  • TH400 trans
  • Keeping the D300
  • Moser 1 piece axles
  • 2-2.5" lift. Don't know about brand yet, OME looks interesting
  • SSBC disc brake conversion
