stereo replacement
spaxton
Springfield
VA
I'm deciding on the direction I want to go in for replacing the non-working stereo in my newly acquired 81. (bought this summer - up til now I've been happy listening to the tires to the road) The current stereo is a Kenwood cassette shaft style that lights up when turned on but gives no digital display nor produces any sound.
I think I'm leaning towards a similar shaft style that works as the Jeep's not a daily driver and I don't want to get into cutting the dash or spending a lot of $. Crutchfield only offers one radio (a Sanyo) that fits for about $80. Any other sources for a deal? I may consider a wireless FM modulator such as the Roady2 to get XM and use it in multiple vehicles down the road.
My Jeep has AC and it looks like I need to take off the dash in order to get the radio out. Is that the case? I also have a hard top on for the winter right now which will probably also have to come off to get the dash off right?
Has a stock stereo ever been stolen from a CJ?
Also, are there speakers on the market that fit inside the dash for better sound than the stock ones?
Thanks for any info,
Shawn
Dang another CJ8 in NVA and we are practically neighbors..let me know if you want to do some wrenching ;) or want to see things completely apart :D . Sorry but I just tossed a couple of cassette radios that would have worked for you. :(
Truck
When I had air in mine, I dropped the A/C down; then I could access the radio. It was still tight or you could pull the dash. I went through 2 of those Kenwoods and gave up, they don't like humidity. I ended up putting an original Jeep (Motorola) AM/FM Stereo out of a "78 Waggy (perfect fit in the original opening) and then I put a high-power Blauput CD AM/FM in my Tuffy console. Last week I replaced my dash speakers (again) with Pioneer 5 1/4" (fits original studs/opening) from Walmart, theyr'e one of the few places that carry the size. You can't get a speaker that has a tweater that sticks way out, I still had to space mine out a little with some vaccum hose on the mounting studs
You do not have to remove the dash to install the radio. Drop the AC system and you should have easy access. I have used the Kenwood KRC-2007 and KRC-1007 for years in Jeeps without troubles. They run about $80 on the net- go for the 2007 for the higher output and RCA connections in case you want to add an amp later. If you want other options in a shaft radio- search Ebay. I recently bought an older model Alpine shaft radio new in the box for $20. Best of luck.
Kyle
I got the sanyo shaft style from crutchfield and it works great. one nice thing about it, is it has a digital tuner. therefore, if you want to use a wireless fmm modulated device (xm roady or Ipod) you can tune right in to the fm frequency. the older "turn style" shaft radios you might find at the wrecking yard won't work as nice.
also, if you plunk out the 300 for an ipod mini and a fm modulator, you don't need a cd player, don't have all the cd's layin around, and it is easily hidden/locked away. thieves will be less apt to break in for a shaft cassette radio!
also, with the cassette on this model, you can get the cheaper xm skyfi with the cassette adapter. easy to plug and play and to remove from your rig.
modern technology is great!
I have one of those Hidden Audio FM tuners in my 65 stang, and it is a pain in the neck , it never works right and you still need to mount it somewhere.
my 2 cents
rick
do the fron speaker pods (the 2 (5.25) that mount on the front hump in front of the shifter) fit under the AC?
Radio
I have had little luck witha radio in the dash on my jeep.. I really like the idea of putting it inside the console.. had it for 3 years and still going strong...I tried to seal it from water in the dash but with no success. Just though I'd mention it...Seen a few people mount them in Ammo boxes and they say it works...
Happy trails,
-Will
If the lights work but no display or sound it got wet. I've been through about 4-5 Kenwood Cassette decks that kept getting wet. I finally draped a ziploc bag over the top of the deck and going on 4 years now and still working great. The Kenwood you have now is a good deck that puts out a lot of power without adding an external amp. I'd try and find another one like it and cover it with plastic to keep water off (almost all jeeps leak water behind the dash in the rain). I've got the Kenwood tape/tuner in the dash and a Sony FM modulated single CD player in the tuffy console. You could just get a tuffy and leave the kenwood you have now in the dash as a decoy. Tuffy's are expensive and I used to laugh at people spending that kind of money on a console, then I got a used one and loved it so much I bought a new one for my other jeep.
Kyle,
I'm just starting to think about the radio myself. Any suggestions on websites to check for the KRC-2007 model?
Craig
One other suggestion. one could go to Boat US, or West Marine and buy a boat radio. There are a lot of shaft styles available, and they are water (proof/resistant). They would probably stand up to the moisture better.
they are mostly white ans $$$$
Crutchfield is the way to go when installing in just about any vehicle as they throw in directions and any wiring harnesses you need. With a jeep you don't need directions and there is no wiring harness to plug into so their prices aren't really any better than Bestbuy or any other place. One thing Crutchfield DOES offer is really good customer service. I've had two stereos and a set of JBL speakers in my jeep that crapped out due to moisture and they replaced them free about a year after I bought them. The last one I sent back they said "water damage" and didn't replace it, but I did send a DVD player back after a year and they replaced it free too (including shipping both ways). If there's anything wrong with whatever you buy from them they'll take care of you......
I am getting ready to install some speakers in my front dash. I bought the 5 1/4 that it calls for but did not think about the tweeter sticking out to far. But I solved that by going to Home depot and got some threaded stock (orange package reads 3/16"-24 x 3/4"). They had a different name but basically it was just a long nut. I threaded that on to the studs already there and used small scews I had to hold the speaker in place. I just put these in the last two days. If you want to do this make sure you put the top one on first and get them to where you want the speaker to fit due to lack of room. It took only minutes to do and looks good to. I am planning on installing the radio in the next couple of days. Things are slow moving since I'm in a cast right now.
Sean
i agree with the above post about the boat supplier. good boat shops sell an indash radio cover that is waterproof with a sliding front. this would require a hole in the dash. however, i wonder if the box (or any similar size box) could be made to seal around the radio from the rear with a grommet installed on the bottom for the wiring. just a thought :)
As far as the speakers sounding better...any speaker will sounds better if you can enclose the back...but no matter what kind of speaker you have you won't get very impressive response by having them mounted the way CJs mount them...with nothing on the back. It would be cool if you could come up with some kind of thin metal surround or something that you could bolt in with the speaker over the back of it. ANY brand speaker will sound better like this.
As far as head unit...I agree with putting it in the console. But I would leave the stock head unit there cause thieves aren't very smart and they will probably just think that's the only one you got.
Crutchfield carries foam baffles that you can use to isolate the back wave and improve the sound. I've used these several times.
Marine in-dash
I had a pioneer installed but due to crappy seals it got wet and stopped working (warranty did not cover it sooo) I've had it just for looks but no one has bothered to steal it (doors open n' all - daily driver) so I felt comfortable getting this from E-bay...Item number: 4522711175. It's a Pioneer cd player that is XM ready (I'd be too lazy to take the SONY XM Module I have in/out all the time) Plus it comes with a sealed box and front cover. It's in the mail and should arrive next Monday so I'll post a follow-up once I install it.
I got a radio from walmart. No CD or tape player. Had SD, USB slots and aux plug. $40. But I wish I had popped for the $60 with the remote. Tiny buttons hard to see and use going down the trail.
The one from JC Whitney will require you to cut the dash- it is not a shaft mount.
Aux is is readily available on DIN size radios.
I'm glad someone was paying attention, lol. I guess I saw the two knobs and thought it was a shaft mount. Thanks for looking out for me :thumbsup: I was about to order it, then I read your reply.
