Sounds good, zr. I'm looking forward to seeing those.
This weeks progress...more plumbing. Got the heater hoses and valve ran, ordered a ton of A/C fittings and parts to make the A/C operational, and mocked up/designed/ordered parts for an air intake, similar to the TJ CAI. Can't say I'm a fan of the CAI airbox systems as a whole, but it was the best solution I could come up with. I'll post pics when I get the box bent up and the tubes installed.
(My other idea on the airbox was to use an enclosed ducted system and have the intake grille using the cowl vent- run the 4" hose around the engine, through the firewall, and into a box under the dash. It really cluttered up the engine compartment, and I was concerned about water intrusion and noise. I may still go that way...)
Also got the PCM bracket built, fuse panel finalized/mounted. Nothing picture-worthy...
Ordered radiator hose adapters too....
Now I'm just waiting on the big brown truck...
Oh...And I'm working on the wiring. It would have been simple to just start running wires, 50 or so
and I'd be done. But...what about 2 years down the road when I need to diagnose something? I figured I'd better do a real wiring diagram...I think that's harder than doing the actual wires!!!
