- Baton Rouge
- La
I figured I'd share a picture of my brushguard for the 8274. I have seen one other photo of a brown CJ-5 with the earlier type of mount for an 8274 and center hoop. The center hoop was a bit wider than this one. I know of one other center hoop that a member on here has. It was not easy finding all of the components. I am pretty sure this is all correct for this 8274 mount.
The winch mount and brackets, orange lights, and center hoop are all NOS. The brush guard needs some cosmetic work and probably not be the one I use on my Scrambler.
This is just a quick mount on my 7 to see how it looks mounted. All bolts are just hand tightened so its not that square yet. I also have the SE 8274 winch to install on the mount.
The brushguard mounts behingd the front of the winch plate so the center hoop is angled forward to make up the difference. Cool loking from the side. Not just a flat look like the nonwinch center hoop
I need to get mine out and installed. I have the turn signals and all as well. I just need to get the winch plate and I'm set. Is that NOS winch plate you have for the 8274 the same one you can still get from warn?
