Intro and Question
Barrett/Fl
Dover
FL
Hello, my name is Barrett and I have an addition to Jeeps!
Ok, with that out of the way I have a question.
I am currently looking at a 82 Jeep Scrambler Laredo and in doing research I find that some have open floor from front to rear and some have a bulhead behind the dirver's seat.
I am presuming that one is designated as a 2-place pick-up type with no back seat and the other is for rear passengers.
can someone explain the difference and which is more desired by most?
Is there a specific VIN designation or something to differenttiate them in ads and such?
Thank you!
BTW: I have a great 95 YJ Wrangler called "American Pride' see the accompanying pic.
To my knowledge, the bulkhead can be put in any scrambler. The bulkhead is needed to put a half hard top (half cab) on the scrambler, which covers the two front seats.
To add to this, the bulkhead/divider is a bolt-in piece. The Scrambler/CJ-8 was marketed and sold as a small pick-up. To my knowledge, removal of the bulkhead and addition of full tops was done by dealers and latter owners.
This not considering the Postals and Export Scramblers....
howell_jeep is correct (unless the body has been replaced by an aftermarket fiberglass or aluminum tub, in which case a factory bulkhead won't fit).
To my knowledge, all the Scramblers sold in the U.S. were sold with a half-top (hard or soft) and bulkhead, in the pick-up configuration. I don't know if any came from the factory (designated for the U.S. market), with a rear seat. However, the nutserts are there for a rear seat and they can easily be added to any Scrambler, and many probably were sold this way by dealerships.
The one exception is of course the Alaskan postals, ordered by the USPS as right-hand drive, one seat only, and a full steel hard top. This World Cab top was otherwise an export-only item, and they can still be found overseas. (And then of course there was that barn find last year, but that's a whole different story.)
Export Scramblers, that had the World Cab top, came with either a rear seat/roll-bar, or else two rows of inward facing troop-seats.
Whether one is more desirable than the other: I suppose that depends on what you want to do with it! Jeeps can be, have been, and are being, changed.
There was not a VIN designation for the bulkhead/top configuration. I'd bet that some dealerships probably swapped the half-tops for full soft-tops, pulled the bulkhead, and added a back seat themselves. Here is AMC CJ VIN info:
http://www.jeepfan.com/tech/tech_vincj.htm
http://www.goldenhawkjeep.com/cj identification.html :
