Label Maker For Wires??
tower210
Olathe
KS
With anticipation pulling the dash and wiring (for a paint job that might be this winter or next). I am planning on sorting and labeling the wires. I have seen the "shrink wrap" type custom lables, but didn't know if those could be printed with a standard label maker (or fit over existing termination - I am not splicing just to put on labels).
Anyone have experience with a good (relatively inexpensive) label maker and labels? Would like to keep below $80 or so, but buying a cheap one where the labels don't stay is worse than no labels.
an alternative
When I did my YJ frame off and also taking apart my 83 Scrambler & 83 CJ-7, I am using plastic ziplocks for the parts & I just use a nice masking tape & Scripto marker on the wires when I took things apart. Just make sure the tape is wrapped securely. Which ever method you decide, labeling is a must to figure out where stuff goes. Also TAKE LOTS OF PICTURES!
I used some nice digital shots for reference when I was putting the YJ back together & very invaluable. Also many pics taken for documenting a father/son project. My wife had a couple books published as a memory of it. She did a great job & each was slightly over $50.
:cheers:
This is the entry level version of the 3000 I have on my service truck. It should be fine for any labeling around the home/garage.
http://www.amazon.com/Dymo-Rhino-Label-Printer-15604/dp/B000PHVVI8
May find "Black Friday' sales online.
We have a couple of versions of the Brother P-Touch around our house. The only difference between them is the keyboard layout. One is qwerty and the other has it in alphabetic order. But the labels are the same and would work. Not sure of the pricing these days but should be similar to the Dymo.
DYMO is one of our clients, I was briefly working on their account and had a meeting at their HQ in Atlanta. Cool thing is I was working on them just long enough to get a Rhino 5200 shipped to me along with a roll of the shrink wrap!!! VERY cool and I'm planning on using it EVERYWHERE.
There's also a sweet function to do flags or wraps with normal label material, just be sure to get proper labels that are for wire/bending. This is really good when you already have connectors installed and don't want to cut them off to run the shrink wrap or are using labels and don't want to swap cartridges. You can set the wire guage and it will repeat the text the proper number of times so that you can see them all around the wire once you wrap it and don't waste tape. The flags are awesome because you can set the flag size and it auto-fits the text or you can let it fit the flag to the text and pick the font size.
I ran a new light circuit in our basement last night and used the flags to label wires with the breaker number :cool:
I totally geeked out on this thing when I got it, one of those things you don't know you need until you get it. I've been using it all over the place and can't wait to do the engine wiring in the Postal!
