This is a bit lengthy; but, I am in need of some unbiased advice about my daily driver...
So, I have found one of 3 vehicles I would even consider getting rid of my '88 GW for; an '04 Wrangler Unlimited... I am just looking for advice one way or the other. I have debated this for a few days and am no closer to a decision than before. Below are some random thoughts that may help you give me advice...
I have had an '88 Grand Wagoneer for 8-years. About 3-weeks after I bought it, the timing chain cover cracked, pumped all the coolant into the oil, and seized the engine. It sat for 6-years. About 2-years ago, I rebuilt the engine. At the time, I replaced nearly all the bolt-on items (dizzy, alternator, starter, EGR, all the CTOs, rebuilt the carb, new radiator, new clutch fan, etc). I have always had issues with fuel delivery on this rig. It took me a while but I found that the fuel sock had a plastic rib that had worked loose and was blocking the fuel line intermittently. Replaced the sock and all seemed great for about a year. Starting last July, it has been giving me symptoms like Vapor Lock / fuel starvation. At this point I have tried all new rubber lines, new fuel filter, new mechanical fuel pump, and carburetor rebuild. Each time I try something it seems to work for 3-4 weeks and then I am right back to problems. I am putting on an electrical fuel pump today and will be checking the fuel sock just to be sure it has not clogged or something. Regardless, my wife has lost all faith in the vehicle (to be honest, she lost faith in it 8-years ago). But, it has hit a point where I am getting nervous driving it too. I am always worried I may not make it home...
The GW is in GREAT shape. There is some minor surface rust under the rubber at the rear windows; but, other than that there is ZERO rust on this rig. Everything works, even the A/C, on it (with the exception of the fog lights I believe they just need a new relay and the cruise control doesn't seem to work). I can say that it has been given a complete brake job (from the power booster / master cylinder to drums/rotors). New axle u-joints and front bearings. MSD6A / Blaster 3 ignition system. The front driver seat is a bit rough but I have a new skin in the garage. There are a few major things I still need to do:
On the flip side, the Unlimited is fully functional. To make it optimal I would look into a small lift and other misc upgrades (fender flares etc). The downside is that I would need an auto loan. I own the GW outright...
- I have a decent oil leak at the oil pump (pretty sure it is a seal related to the mid-plate)
- Have some seeping at the transmission cooler lines...think it could use new o-rings and maybe the band adjusted (the one inside the pan has been adjusted)
- Have some seeping at the valve cover and oil cover, planning on using Great Stuff on them
- Should grease the speedometer cables
- Want to replace the two stage power valve with a single stage
- The headliner is odd (the cardboard is dented above the drivers head) and the rear fabric needs replaced
- Should replace the drive shaft U-joints
- The oil and temperature gauges are off a bit (temp reads about 20* too high and oil reads about 10# too low) I have verified with mechanical gauges
- Would be a good idea if I replace the fuel tank vent hoses I just don't want to drop the tank
- Would like to remove the whole interior, coat with Rust Bullet, sound deadner
- Remove rear windows and coat the surface rust with Rust Bullet
- 2-inch add-a-leaf
- I have gears for a re-gear
