? for those with fiberglass tubs and full roll cages
sevensandeights
sevensandeights
Mckean
PA
I am considering a fiberglass replacement tub for my Scrambler. Do any of you guys with fiberglass tubs run a full roll cage? If so, how did you attach it to the body and the frame? What top are you running?
Not fully on target, but I have a project CJ-7 with a full fiberglass body and roll cage. The cage is attached to the frame in 8 places. The cage is bolted to outriggers welded to the frame. I sandwiched a thick rubber pad into each attachment point to allow some degree of flex. The cage can also be removed by doing this. I have no top, but there is no reason one wouldn't fit on there.
I have a fiberglass body on my cj7 and a full cage.
And I'm in the middle of a cage build on my wifes
glass cj-8. I have a six point cage in my cj7 that is
typical to any six point family cage in any jeep as
far as mounts/ style. and I'm running a bestop supertop
soft top. but I had the cage made to fit under the top.
And my wifes cj-8 is going to be the same. I have a bestop
cj8 soft top and the cage is being made to fit under the top...
The nice thing about the mounts my guy is doing for the cage;
the fiberglass body mounts don't line up with the frame and you
have to buy an adapter kit or move the mounts on the frame
to match up with the body. IMO the adapter kit/plate is ugly. but
with the full cage I'm going to make the b pillar mount from the frame to
the body a cage tie in and a body support... so I'm getting two birds with
one stone... I did't use a rubber mat between the cage and the floor but I
have a rhino liner in my jeep. so the buffer was already there.
I don't have pic's of the cage in my wifes cj-8 yet. I'm still in the design stage.
thanks,
7jeeps7kings
Could you just incorporate the tie-ins to the adapter plate? The frame I bought already has reinforcement plates welded to the outside so if I move the body mounts then I would have to alter the plates as well and then put more plate where the body mounts were moved from.
I guess it all depends on what you want it to look like... if you keep the adapter plate and incorporate the cage tie in... it might look like you have a lot going on. but again it depends on how you want it to look. and to tie the cage into the adapter plate would also depend on the size of the plate you currently have. I know the stainless steel plate I got from 4wd was not thick at all. and after finding out how the kit work I sold it! but thats just me. I was looking through my cj7 pic's looking for a picture of the cage tie in and the frame body mount supports but I could not find one. and my jeeps are away for winter. so maybe someone else will jump in with some pic's to show you want I'm talking about.
7jeeps7kings
Take a look at M.O.R.E. Mountiain off Road Enterprises, They have a kit that they sell for a front hoop on a CJ or really any Jeep. It is a way to make a tie in to the frame that is similar to the body mounts.
You could easily fab up something like that or buy theirs if you had more cash than time.
Carl
I just bought a bunch parts from M.O.R.E. ! Their method seems pretty straight forward and easy to install/remove.
I am leaning away from fiberglass now that I have a line on a metal tub. If I do go fiberglass though I don't really care what the tie-ins look like because most of it will be covered since I am going use the Poison Spyder rocker panels that tie into the body mounts.
