and as I'm going along here, for re-usable hardware (see the bolts above holding on the bump stop and the braces), I used my bench grinder (wire wheel side) to clean them (both the threads and the bolt heads).. most of the hardware cleans up well, but will eventually get ugly or rusty or discolored again as it is graded (and not stainless), which brings me to a little question/decision point..
what do you do with old hardware when you're mounting new (or cleaned or painted) items? For most of my graded requirements, I'm using new replacements from the Lowes bolt bin.. but most of their graded hardware lacks the "attached" washer sets that many factory fasteners have, so you have to also buy those.. for my chassis alone, I spent over 100$ on replacement bolts.. it's not a big financial commitment, but it's a hassle to have to go get it..
for items that I have on hand and don't HAVE to be replaced (like those pictured above), I've been cleaning them, but painting them before installing is no good (spray paint chips under torque/wrench action), and painting them AFTER is going to be time consuming/tedious at best (ie: by hand with a touch up brush...
i was wondering if there's an alternative way to handle this?
finally, for things that often prove to be a PITA to take out (think roll bar bolts), is it worth doing something like an anti-seize compound on the threads before they go in? I'm going to hex-head bolts on those (and on many of those fasteners that I'm fully replacing) so they should be easier to get out anyway, but the thought crossed my mind.. I'm sure someone here's going to tell me and go the opposite direction (ie: put loctite on them) for safety reasons.. just curious if I was the only one considering this..
in the end, with limited time on hand to get this thing as assembled as I can before we move (from FLA to CO in January), I may not have new hardware, and commit to replacing things bit by bit (so to speak) someday down the road..
