Rollbar curtain/Wind jammer
mysunnshine
Phoenix
AZ
Has anyone used these before in their Scram? It's getting chilly here in PHX now and I'd like to cut down the volume of air that the heater needs to support. So if anybody has had sucess using one, which model(CJ/TJ/ETC) worked and/or fit the best?
I'm not really sure how well this setup will work in a Scrambler, but I have a grey setup from a YJ that I will make you a really good deal on. The one I have has the bikini top, bed cover, and the divider between the cab and the above bed area. Let me know if you might be interested.
I have and use a CJ-7 windjammer in my Scrambler at times. It fits well, it attaches with straps to the roll bar and 3 short sections of track at the bottom.
I have used them on a Cj-7 before and does a nice job keeping the strong wind from whipping backwards on ya when driving at speed.
I have a brand new windjammer in black, just the part with the window, for sale for $40....you can find pics at www.jerseyjeeps.net then click on current inventory then "jeep parts for sale"
Good. I was worried if the straps would be too short to go around the larger diameter Scram roll bar. Thanks-
I used a wind jammer from a YJ all summer in my 85 Scrambler. It worked great! I also used a bikini from a YJ but I had to make a wooden support system to put a little "poof" in the top so water would not collect. :evil: The windjammer fit great but of the two bikinis I have from a YJ, only one would fit due to differences in the straps. The black one I wanted to run had straps that did not fit. The gray one I was able to make work. Then I also ran Bestop full soft doors that split. I just kept the uppers behind the seats in case I ran into ran. It sealed up the pass compartment pretty well.
I meant to post some pics I took this summer but lack of coffee in blood made me hit submit key & edit did not allow me to add photos to previous post. Then when I looked, I only had pics of a YJ/TJ trail cover I used this summer to keep it dry when it rained. Basically, the windjammer fit just fine. The straps were a bit snug because Scrambler bars are larger diameter, but worked great. The bikini I had a bit more trouble making fit but in the end it fit nice too. The wood pieces to keep rain from collecting were just made from a medium hardwood that was still flexible enough to bend. I fastened two into a cross shape then cut them to fit under windshiel & bikini and over top of roll bar. The piece going across the passenger compartment, the ends floated.
Hope this helps ya! :D
I used a CJ7 windjammer and bikini with hard door up until I mounter the 1/2 hardtop for the winter. I did a little mod to the windjammer...shortened the bottoms so it mounts a few inches down on the bed (out) side of the bulkhead. Just some cuttung and hand sewing the plastic strips required. I also mounted the footman loop for the bikini to the bulkhead.
It makes for a smart, clean fit, but there's still quite a chunk of breeze behind your neck. That space between the doors and windjammer feel HUGE on a chilly day :)
