Interesting ride home today .
skell22
Mechanically challenged
Collegeville
PA
Today I was driving the Scrambler home from my local Eastern Mountain Sport , when all of a sudden it sounded like a throaty V8 ( it has a 96 4.0 from cherokee ) I pulled into a parking lot and discovered that the exhaust pipe in front of the cat had become separated from the clamp and pipe coming from the exhaust manifold . I also noticed that the brace that holds the exhaust system to the bottom of the jeep was separated . As it turns out I am to blame for this. On Friday I went to Quadratec for some seat belt sleeves to keep the female portion of the seat belt from constantly falling down between the the seat and center console . I installed the sleeves , but I did not know that the drivers side bolt for that female portion was actually the bolt that held up the exhaust bracket where it comes through the bottem of the jeep . Are all CJs like this , or did one of the previous owners rig it this way ? I'm sure that after 10-15 miles of a loose muffler system was enough to separate the pipes . Should be an easy fix but was wondering if that bracket should be mounted differently . Thanks and I hope you all had a great Christmas . Chris
So you got me thinking because I have a stroked 4.0l what is a good sounding muffler with that engine?
Don't really know . It is the same muffler that was used when I had the 258 . It sounds about the same as it was with my 258 too..
Warranty
Previous owner got you.
Sorry Chris. Didn't mean to. :shrug: I'll go to the bank in the morning and send you a refund. Pick up the Scrambler tomorrow afternoon. :woot: :D
:wave:
:wave:
Funny Toby .... By previous owners I meant the one in SC and before . ... Can you believe that, unscrew the bolt to the seat belt and I disconnect the bracket to the exhaust ? Kind of get the idea of the sound of it had Brian put in a 350 .
All good.
Have a great night. I just couldn't resist. :)
:wave:
Just so it's clear to the OP, this is clearly a rig from the PO as in stock form, the exhaust system is attached to two solid mounts off of the frame. There is a frame extension that holds the center mount and a rear mount in front of the left rear shackel hanger. Sometimes I've seen the transmission mount extent up to the exhaust mount as well, but not common. No brackets or such comming off the body till 87 when the YJ used a body hanger with rubber hangers. No seat belt bolt though.
