mpg with 4 11s and 35s
ZRMiller
charlotte
nc
what would be a guess or actual mpg i would get with a 258 with a t5 411s and 35s im looking at 4 11s because my dad thinks 456s are to high for daily driving. and therefore would get bad gas milage. and im thinking 411s would get like 15 mpg in the city,
thanks you guys always help
welll that question is hard to answer because other factors need to be considered. For one the condition and tune of your engine. How many heavy after market parts you have. How big of a lift.
I think 15 around town is a little optimistic. At best I would guess 16-17 highway and 12-13 city. Your jeep is big with 35s and pushing allot of wind around. Also those tires are heavy and it takes work from the engine to turn them.
Just for reference when talking gearing, the 4.58 is a lower gearing than the 4.11. It is opposite of what people think.
No idea on mileage, but the 4.56 will make 5th gear actually usable...
I have 4.11's, 35" tires, T-176 (no overdrive), and a 4.2 with the Mopar MPI. It gets about 16mpg running 70-75 down the interstate, approximately 2700-2900 RPM. Not sure around town MPG, never tried to measure it, probably 13-14:shrug: My motor seems to be in excellent mechanical condition, runs like a scalded dog, considering it is just a 6 cylinder pushing 35's:thumbsup:
I have 4.10 gears with 35 BFG AT's, T5 and stock 258. Mileage is around 15 but would not recomend 4.10 gears with 35" tires. I went with 4.10's for 33" tires and decided I like the look with 35" borrowed from my Chief. Jf you have an OD tranny go with 4.30 gears (easy to for Dana 44's).
Richard
4.30s
I agree with Grantshire (and a bit with your dad). The temptation is to often "Over gear" our Jeeps. To little gear (lower numbers) and the rpms are to low and the engine requires more to get it moving. To much and the engine spins to fast at road/highway speeds, burning more fuel and maybe wearing parts faster? You want to do the math using a gear calculator like this...
http://www.grimmjeeper.com/gears.html
and look hard at many angles. How much road vs off road will you HONESTLY do. As mentioned, how much aftermarket (heavy) stuff have you added. Etc... I have 4.10s in mine but I have a 360 pushing it around so power isn't a problem. But since its still tuned for altitude and I have added a BUNCH of extra weight, I'm sure 4.30s would have been better. I'll know more once I get the NV4500 installed... :)
There is a minimal RPM difference between 4.10's and 4.30's....
Yes, about the same difference as 33" tires vs. 35". With a stock 258 it makes a difference, with a 360, built out 258/4.0 head or 4.0 I would go 4.10, 401 power 3.73 would even work. My stock 258 struggles to maintain 70 mph on flat ground with a head wind. On the other hand, my Commando with the tricked out 4.3/999 combo still has power at 80 mph and it has 3.73 gearing with 39" tires.
One Item I found that made a huge difference, but you might not be able to do this where you are. I have collector plates on my Jeep which means I don't have to get smog tested. I took out all the vacuum lines and up graded to a high energy ignition. I also removed the smog pump and air rail on the manifold. I run AMC20 and Dana30 4:10 gears with 33"x10.50" and getting 20mpg on an average daily trip. I drive roughly a 90 mile loop each day mixing rush hour traffic, open HWY and inner city in that trip.
Prior to the cleanup I did my mileage was as poor as 10-13mpg.
Now I need to re-invent a new Hydrogen Cell and give that a try again with a smoother running engine. With lucky maybe I can pull 25-28mpg at 5000 feet above sea level? It is all a game.
Really the main tip would be to let the engine breath with a hotter spark. Good luck with your fun.
rebuilt (less than 1,500 miles) 4.2/4.0L MPFI, T-18 (no overdrive) 4:10s, Dana 60s, 37s. 13mpg highway.
4.0L, T-5, 4.11s, 35s... 16-17mpg average when I drove it home from California. 5th gear worked fine.
