painting my hard top
I don't have a good representative photo, but my original hard top in the medium brown/tan color looked terrible.. as I'm running out of time before I move, I debated about doing anything with it 'til later... but decided (in lieu of an actual restoration), to give this a shot..
the top is flaking, chipped, faded, boogered up with years of old gasket material and silicone, but otherwise solid.. here's a pic after wash #1 with some Simple Green
the inside is actually worse: the fiberglas woven material is showing through, and the paint looked terrible and dirty, and PO(s) had done some no-mask spray paint jobs in there so.. here's some before shots including a close-up:
I don't have any "after" shots of the inside, but all I did was SimpleGreen it, rinsie and blow it out with my air compressor, and then spray bomb it with some rustoleum white semi gloss.. I only had (most of) one can of paint, so I did a very light top coat to even out the color a bit and cover up the stains.. what the inside really needs is probably a skim coat of bondo, a good sand, and then a better paint job.. and maybe a carpet kit a'la Stu Olson's website DIY.. more "for later" jobs!
on the outside, I rinsed and blow-dried it, then did about three wipe downs with some acetone (which was mostly just pulling off the old original paint/dye).. here's after the acetone:
and then started my 15$ solution:
this is one coat (will probably do three total) of a Valspar (yes, that's exterior home paint from Lowes) product called "Duramax", which is latex, but reportedly their toughtest finish in a color called "Cowboy Suede".. sounds ghey, but the color was about DEAD ON for the factory tan top.. I used a 2 inch nap roller for the main body and a 1 inch foam brush to cut in the edges..
I can see some streaks/uneven paint coverage from the first coat, but the nap of the roller left a good textured finish (I was a bit afraid at first 'cuz it had THOUSANDS of air bubbles in it, but they all settled out), and one pretty good coat took less than 1/3 of the quart of paint that I bought... super easy to apply, not very messy (easy clean up), and the actual paint job only took about ten minutes.. the longest part of the whole day was letting the top air dry after I rinsed it, but I was working on other stuff at the same time (see below)
I'll do at least one, probably two, more coats and then install it.... and report back at a later day on how it holds up.. if it doesn't work out, not a big deal because I (a) plan to go with a full length top to replace this, and (b) it's a simple repaint with something else later if this doesn't work, and the top really needs a full resto anyway
I also have a nearly un-attached metal strip on the winsheild edge of the hard top and need to figure out how to reattach it... I bought a rivet gun kit today, but have never used one before, and am afraid of damaging the fibreglass even worse
I'll have to do some online research and see what I can come up with
