Mounting brackets after full paint.
Nauticalfly
Lagrange
Ga
Hey guys got a question. I am doing a frame off restore of my '81 scrambler. When putting the brackets and hinges back on I hate the idea of paint to paint. Do they make or any ideas on what I can put between the fresh paint? Thanks!
I haven't tried it yet, but, I plan on applying vinyl decal material to the back of the brackets and hinges.
I hope it will work similar to the way the the material applied to rocker guards is advertised to work.
Just an idea so far.
On another forum. A member took his cj7 to a local sign shop. Was able to get a color of stick on letter material that matched his paint. He mentioned he cut the pattern just a bit smaller than the bracket. Then stuck it to the bracket instead of the body.
Sounds like a bit of work. I can't help but wonder if it might be a problem if you ever had to remove the bracket later.
Interesting question. You could use the same method for the space between the rollbar and the tub.
I usually put a nice coat of grease and then bolt the parts together, that way rust doesn't develop and if I have to remove them they come apart immediately.
The decal is a great idea. I will definitely look into it. And the fact it can be hidden is awesome. When I took the rollbar off I didn't notice anything between the metals but all was pretty rusty. I will have to try to find those as well. Thanks guys!:cheers:
If it's going to sit outside and you're worried about this then apply some clear silicone between the pieces--once cured it will provide a good seal and will last the life of the resto. I generally go the silicone route if needed--cheap and effective. Do this under the hinges for the doors, the windshield, tailgate, spare carrier and between the seams on the fenders and you should be good to go. I think the vinyl material thing is way too much work for the benefit received.
If you go with the clear silicone, be careful that you use the non acid curing type. The type that uses acetic acid to cure will actually promote rust between the parts.
