Yes I would like to go that high. I was considering 1 tons. But what would I have to change to steeringWith the 4 inch springs and shackles, you are going to have about a 10 inch lift, and be able to run 38 in tires. Thats a pretty big lift. I ran that setup on my CJ7 for offroad. Is that how high you really want to go?
If so, minimum should be dana 44's, rear Ford 9in, or one tons. You will need front/rear driveshafts, maybe a rear CV shaft, shocks, brake lines, steering, etc.
Manhattan, thanks for your advice. so you would recomend keeping the same suspension setup and upgrading the axles?
